Question about KitchenAid KGST307 Gas Kitchen Range
Moved range from home to cabin. Now when trying to use oven it won't heat. By turning on one burner on the top the range will heat. If we turn off the burner on the top the oven will continue to heat. However, when it reaches temp and shuts off, it wont relight when the thermostat calls for heat. If we turn the burner on again, the oven will relight and heat-up. What is wrong and how do I fix it?
  • wmellgren_1 Sep 04, 2010
    The response posted dosen't make much sense since the expert is addressing an electric range top burner and my problem is with a gas range oven. can someone else help?
  • 10,865 Answers
Replace the thermostat. Often these stats do not survive a ride down the highway. J.
Posted on Sep 04, 2010
    Genius:
  • 1,478 Answers
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
  • Jimoh Adeleke Muyideen Sep 04, 2010
    The problem could be that your portholes are clogged from grease or food. To gain
    access to the portholes, lift the range top and lift up the burner
    assembly and pull it out. This is the round part that has the little
    holes all around it with the pipe that runs to the control knobs in the
    front of your range. Use a small thin piece of wire or a sewing needle
    and insert the wire or sewing needle into the holes, taking care not to
    deform or enlarge the holes. Now wash the burner heads in hot soapy
    water and replace them making sure the port holes line up with the flash
    tube leading to the pilot.
Oven won heat unless burner is on
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
I have a Kenmore Range Model 911.7378710. The oven won't turn on. The top burners are working. When I turn the oven knob, there's no sound, It's an old stove and I can't find if even...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 24, 2011 | Kenmore Kitchen Ranges
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Dec 21, 2007 | Kitchen Ranges
KitchenAid KGST307 Gas Kitchen Range Logo
76 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
