I have an acer aspire t180 desktop i have purchased a new ram and would like to install it, i have removed the side panel like told on here however i dont know where the ram needs to be placed as all is visible is the back of a motherboard please advise.
    Problem Solver:
  • 8 Answers
Installing RAM is very easy. First of all make sure the RAM you bought is compatible with your system. If you not sure visit crucial web site and scan your system with their program.
After that please watch this video
Visit Somdtech.co.uk
Posted on Sep 05, 2010
Ram install caused beeping and no boot-up
Remove the ram and use the known good RAM. If your motherboard has more than one slot then try the other slots in your computer.
Apr 03, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
Can't get the side panel off my acer aspire ast 180-UD360A
Hi I was suppose to provide you the instruction however it would be better if you will see the images including steps on how to remove the side panel of your tower..This website will help you a lot ..
http://global-download.acer.com/Step5.aspx?Step1=Desktop&Step2=Aspire&Step3=Aspire%20T180&BC=Acer&Category=Document
Nov 17, 2011 | Acer Aspire™ T180 PC Desktop
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
I want to upgrade the video card on my acer aspire t180 desktop
You will want to purchase a PCI-Express video card. Open up the side of the computer and place it in the appropriate spot to use the new video card. Check here for some possibilities.
Mar 13, 2011 | Acer Aspire™ T180 PC Desktop
Acer Aspire T 180 stops with Acer Logo
What you were trying to do tried to remove the RAM and boot your pc. Buddy once you remove your RAM you are going to get long beeps as it tells there is no RAM on mother board and it won't boot. Just install back all the things and let me know how many beeps you are getting and what type short and long.
Feb 22, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
My acer aspire t180 ua380a desktop comp will not post. I turn on the comp and the red light comes on but no green lights and again the comp will not post. I have reseated the ram and cpu.
If it won't post you have a bad memory chip or memory slot try a different slot. Do you have more than one stick of ram? if so remove one stick and try it in different slots, if it does not post then buy some new ram.
Jun 13, 2009 | Acer Aspire™ T180 PC Desktop
Opening side panel of acer aspire t180
You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
Jan 23, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire Desktop RAM
I am not for sure why, but sometimes resetting the BIOS to the default setting will allow the computer to restart.
Dec 10, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
