Question about Toshiba Satellite A25-S207 Notebook
Why wont my Toshiba Satellite A25-S207 turn on? i plug in the charger and there is no light. it doent turn on why??? is it the battery????
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 06, 2010
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite a25-s207 spontaneously shuts down
Ron from your post it isn't clear what your actual problem is. Can you be more specific
Jun 08, 2009 | Toshiba Satellite A25-S207 Notebook
Possible mishap with the power?
there are different ways on how to check the problem you encounter regarding on your machine. kindly follow the procedures below:
- first take out the battery and plug in the power supply. if it works, suspected it's a faulty battery (if your machine is under warranty call the service center for the replacement of your battery
- if the machine won't turn on after taking out the battery and pugging in the power, take out the hard disk, plug in th power. if it works, suspected hard disk faulty. (replace hard disk)
- if machine still won't turn on after taking out the hard disk, take out the memory card. you will hear a beep sound after taking out memory card. if it works suspected memory card faulty. (replace memory card)
- if you didn't hear any sound after taking out the memory card, suspected motherboard faulty. (replace motherboard)
May 27, 2009 | Toshiba Satellite A25-S207 Notebook
Three possible reasons why this has happened
1 - The power supply cord has a faulty or broken wire somewhere and needs repairing. Take a good look and see if you notice anything out of the ordinary (UNPLUG THE POWER CABLE FROM SOCKET AND COMPUTER BEFORE ATTEMPTING TO LOOK)
2 - There could be a physical problem with the plug or socket for where it connects to your laptop and needs to repaired or replaced
3 - The computer has short circuited with the power cable socket in your laptop preventing any power for the Laptop
Hope this helps
Nov 18, 2008 | Toshiba Satellite A25-S207 Notebook
Wireless connection
on the left side is an on and off button,is it on. what is the name of your router and adapter if is used.
Oct 25, 2008 | Toshiba Satellite A25-S207 Notebook
Satellite A25-S207
wiggle the ac jack in the back see if it's loose it may need to be resoldered.
Jan 21, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba A25-S207
That flashing light indicates that the laptop is not getting power, check and test your power cord. That light should be light solid when plugged in. good Luck
Sep 18, 2007 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S207 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
