Question about HP LaserJet 3055 All-In-One Printer
No paper pickup error in hp laserjet 3055 printer
I have hp laserjet 3055 printer and its giving me no paper pickup erron in pannel. i did losts things there is not paper atall in front and back there is paper come out i also played with roller when i trun on that time there is no motor sound.i think motor is not trun on . any one help on this thing.
  • 2 more comments
  • vladson May 14, 2008
    hp laserjet 3055 printer giving me "no paper pickup" erron in pannel.
  • Anonymous Jul 25, 2008
    No paper pick up error. No paper jam, pulled toner cartridge and replaced, removed and refilled paper tray, checked roller mechanism, turned off/on, etc. No success.
  • Anonymous Aug 26, 2008
  • davrchy757 May 15, 2009
    Error Message:
    No Paper Pickup
    Press {Enter}
    Pressing enter or check mark has no effect.
5 Suggested Answers
SOURCE: Hp 3055 laserjet scanner problem
That scanner was not the greatest.
remove the glass and clean the bulb and mirrors.
This helped my problem.
frank
Posted on Jan 15, 2008
  • 35 Answers
SOURCE: HP Laserjet 3050 No paper pickup
NOTE:
If the printer DOES NOT PICKUP paper .
That is a jam also so the places to look are smoth rollers or smoth spots on the rollers.
trays not adjusted properly and if they have it some trays have a coustom/standarsd switch (should be in standard for letter/legal paper
Posted on Jun 13, 2008
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
frankzjm
  • 191 Answers
SOURCE: How to replace a pickup roller in Tray 2, HP LaserJet P3005n
please reference here:
https://www.laserpros.com/hp_P3005_tray_2_pickup_assembly.asp
hope you fix it well
Posted on May 13, 2009
xptareq2000
  • 1447 Answers
SOURCE: HOW TO CLEAR PAPER JAM HP LASERJET 3055?
please you see your copier paper feed sensor is open or delivery sensor is open or broken
Posted on Jun 28, 2009
No paper pickup, press enter
Suspect worn and or dirty paper pickup roller. To check the roller simply open top cover and remove toner cartridge. Roller is D shaped and can easily be removed by gently pressing the two tabs outwards. This should pop out the roller from the holder. Clean roller and check for wear. If worn replace.
Feb 23, 2010 | HP LaserJet 3055 All-In-One Printer
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 Laser Printer. How Do I clear?
open the printer remove toner cartage and see inside the any paper are jamed in printer remove the paper and if the problem is not solved the contact me i will told you what to do
Jul 11, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
No Paper Pickup
turnoff the printer n reseat the tomer catridge properly ,take care it should not be tilted on side,check it that it seated properly,power on the printer n check ,can u hear any motors moving sound,if yes check the printer now,if not check for any peice of paper inside the printer especially from where the paper comes out
do revert
thnx
Jan 25, 2008 | HP LaserJet 3055 All-In-One Printer
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
345 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
