Question about Amana DRS2462B Side by Side Refrigerator
I need to defrost every couple of weeks - Amana DRS2462B Side by Side Refrigerator
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
Ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
May 22, 2012 | GE Refrigerators
Hi please help my freezer has stoped freezing things and my fridge is pretty much room temp. it still sounds like it running. what would this be? thanks Mel
u have a defrost problem..it needs to defrost. then it will do fine for a couple weeks.. u need to replace your defrost timer. ok
Feb 11, 2011 | Refrigerators
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
No heat or defroster
my guess would be the thermostat has stuck open and needs replaced
Dec 26, 2008 | 1997 Plymouth Grand Voyager
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
The Fan of my hotpoint ff175b got noisy becouse of ice deposition. Is that a common or serious problem? I have deiced it once - it was fine for a couple of weeks then it's same again. What shall I do with...
you have a defrost heater defrost bi-metal or the defrost timer bad one of theis is the problem need to isolate the problem with the wiring diagram
Apr 16, 2008 | Refrigerators
Amana DRS2462B Side by Side Refrigerator Logo
62 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
