My LG DVD Player gives off sound but no pictures even after correctly connecting the cables. It used to give off both the sound and pictures before I touched a button on the remote control
    Genius:
  • Televison & ... Master
  • 1,689 Answers
I don't know the particular model, but I can give some generic type suggestions.
Look in the user book to see if there are any resets. If you can see the menu on the screen, check the default video output. It may be set in a format that is not compatable for your TV set. I have seen that from time to time.
I am assuming you checked all the interconnect cables and that there are none that are defective. You also checked that the input on the TV you are using is working properly.
Jerry G.
Posted on May 12, 2008
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Coby KTFDVD 7070 unable to access tv channels
check that your set is set to the correct source. if one source doesn't work another should, say a dvd player. if a dvd player gives you a picture then either the connection or cable you are using is bad, possibly the tuner. it sounds like a connection problem to me.
May 08, 2014 | Coby Televison & Video
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Hi there..I have an L G tv and a philips dvd player. Recently my dvd player will only produce sound but not show image..is there a problem with my dvd player or the L.G T.V
Check if the cable you are trying to connect is working properly. to check it just use the video wire and connect both ends to audio input and output respectively.If the tv gives out the sound your cable is the problem.Do this and if you do not get sound do contact me and I will solve your problem.And also please do vote my answer below.Thank you.
Jul 20, 2011 | LG 42LC2D 42 in. LCD HDTV
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Vizio hd L37 tv not showing a clear picture
what type of input and device are you using? what type of connection? HDMI, Component, AV? DVD player, VCR, Cable/Satellite? Using HDMI will give you the best picture and sound. Best way to test is with a blueray or DVD player using HDMI input. If your picture is still bad, change the main board.
Dec 17, 2008 | Vizio L37 Television
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
