Question about Frigidaire Gallery Side By Side Refrigerator 26 Cu. Ft. GLHS69EEP
I have a Frigidaire Gallery GLHS267ZA refrigerator. About a month ago the ice dispenser makes a growling noise when dispensing ice. Now yesterday although the freezer setting is at 4 and the fridge side is at 5, things started freezing in the fridge side at random locations. The water dispenser stopped dispensing water and the icemaker stopped making ice. late last night water started dripping from around the water filter. The filter probably needs to be replaced, although the red light never came on. I don't know if all of these issues are related to needing a new filter or if other things, such as the control area, needs to be fixed. My husband turned off the water until we figure out what is wrong.
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 1214 Answers
SOURCE: water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: FRIGIDAIRE SIDE BY SIDE FRS26LF8CSN
alkimike;
I had a problem with my icemaker not drawing water or making ice, I did a full defrosting of my freezer taking everything out leaving the door open for about 1.5 hours It appeared that the inlet water supply had an ice blockace up in the water outlet, defrosting it cured the problem, it has been workinf fine for the last day tub is full of ice!!
Posted on Jan 29, 2009
tborn6
  • 700 Answers
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Posted on Jan 30, 2009
Frigidaire Gallery series ice dispencer does not dispence ice. Also, what is proper freezer setting?
Thank you for your inquiry, friend!
Based off what you have described you are having trouble with your ice dispenser not dispensing inside of your Frigidaire refrigerator and you would like to know the proper temperature setting. You may want to open the door of your freezer and check your chute to assure that there are no ice chunks or frost causing issues with your ice dispensing. When you push on the paddle do you hear a noise? If you do not hear a noise your auger could be bas inside of your icemaker. If you hear a noise and no pushing it could be a possible problem with the motor. It is recommended to have your freezer on a zero degrees for a factory setting. I hope this information is helpful. If you need any further assistance please feel free to reconnect. -Matt
Feb 21, 2015 | Frigidaire Refrigerators
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire Gallery Side By Side Refrigerator 26 Cu. Ft. GLHS69EEP Logo
112 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
