Question about Car Audio & Video
Blue screen / cannot get display
Blue screen comes up when the unit is turned on. the display has come on and went out before. Do you have any info on this product?
  • bossin Oct 07, 2008
    screen pwrs up flips out starts blue screen, then when dvd is played screen goes to blk & wht static screen. any suggestions?
    Genius:
  • 1,224 Answers
Loose wiring or over heated monitor
Posted on May 12, 2008
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Display went blank to the calibration screen while traveling
Try using a stylus if you have one or a pen (tip retracted) on the screen. Meaning something finer and thinner then your finger. Don't know why but this works on my unit when the recaibration screen comes up.
Nov 27, 2013 | Garmin nuvi 255W GPS Receiver
Laptop screen has gone blank
I assume that your laptop's display has been damaged. Are you sure that other things are working normally? If other components are working, then problem will be with the display unit. Try to repair or replace with new one.
Nov 28, 2012 | Compaq Presario CQ56110US Laptop
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
I have the unit hooked up i can hear the cd and the radio but the display only shows a blue screen if i go to the set up screen and hit the back buttom i can see the display for the cd and or the radio...
All I could find out about this problem, is that the screen's reverting to "stow-away mode". It could be doing it because of a problem with the touch screen (intermittent sensor connectors). The screen is TFT, and can also have damage if bumped, but from what I've read about these type of problems, it's often the touch sensor connection in the display. There are YouTube Videos about repairing touch screens, and I saw a couple on the ipods, which is a similar system. It's quite a process, but can be done with disassembly and a heat gun. Your problem could also be a slightly loose ribbon connector, with just enough intermittence to default the cpu to the stow-away mode. If the reset isn't working, it's either the screen or a ribbon connector, and those are easy to reseat, after you get the unit apart.
If you do get it serviced, get an estimate first. Then you'll know whether or not you want to try it yourself, or go another route.
Good luck, and hope this helps.
Jul 04, 2010 | Car Audio & Video
No power?
i just picked up this same unit model and 1 thing is your backwards on the LED on/off...its blue when its off, and LED goes off when turned on.
Hopefully this will help determine if its off or on
RandyMan
**Life isn't about waiting for the storm to pass...its learing to dance in the rain!!
Jun 08, 2010 | RCA Audio Players & Recorders
Permanent blue screen display
I had the frozen blue screen twice. As a cowboy reset, I removed the battery for a minute, then put it back in. Worked for me, didn't erase my contacts or anything.
Oct 22, 2007 | LG VX5200 Cellular Phone
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Car Audio & Video Logo
212 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
