Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
When i turn it on loc comes on and i cant get it to work. i tried yesterday and it said pause then error
    President:
  • 1,554 Answers
The control is locked as what "LOC" indicates. Press the Options and Select buttons simultaneously for 10 seconds or until "LOC" is no longer displayed. Pressing the same buttons for 10 seconds will lock the control. There is actually a padlock sign marking between these buttons to indicate that these buttons are used for locking and unlocking the control.
Posted on Sep 04, 2010
What does Lc mean on my Whirlpool frontload washer?
lock
LoC or LC - Whirlpool Home Appliances
producthelp.whirlpool.com/Troubleshooting...Front_Load_Washers/.../LoC_or_LCApr 22, 2017 - If you try to push buttons, you may see the code "LoC" or "LC" ... For each second CONTROL LOCK is held down, the display will count ... You may still touch START to pause the cycle, or touch POWER to turn off the washer.
What does Lc mean on my Whirlpool front load washer Google Search
Jun 24, 2017 | Whirlpool Washing Machines
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
My machine has been coming up with F.06 on it and i cant find the manual to find what this means
This error code indicates that the motor is having difficulty turning.
Are the shipping bolts removed?
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes.
When they are removed, to remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Aug 16, 2011 | Maytag Washing Machines
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Oven wont come on
Cleaned the oven yesterday with self clean and the next day while cooking on the top it just stopped working
Dec 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
