Question about Cuisinart DCC-1200 Coffee Maker
I have a CWDGB650BC coffee maker, purchased 4/22/10. The coffee beans grind but the water does not heat to brew the coffee. Help! Thank you.
  • harryablr Sep 04, 2010
    I feel this is probably an electrical problem.
    Guru:
  • 302 Answers
Seems like the heating element of your unit is not working. There can be a few reasons for it.
1. The heating element has been disconnected form its power source.
2. the heating element is faulty in itself.
I f you have warranty on this item you should better claim it.
Posted on Sep 04, 2010
  • 10,319 Answers
Probably clogged up. Add a few ounces of lenon juice into it and let stand over night. Add one cup of water to it in the morning and turn on
The lemon juice will remove the scaling in the tubing of this coffee maker
Why does my DGB-300 grind coffee but doesn't brew?
having no idea where it get water from does not help us figure it out , would suggest checking with the manufacturer's website for technical support .but 15 years is a good long life . some burn out in only 3 or 4 yrs
Sep 17, 2017 | Cuisinart DGB-300 Coffee Maker
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Jul 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
