Question about Kenmore HE2 Plus Front Load Washer
Leaking like crazy and only 2 1/2 years old. Where are the screws so I can take the bottom panel off?
  • 347 Answers
Their are 3 screws holding the front lower panel onto this unit.If you can tip the machine back some and put a block underneath it will help you see and remove the screws ,I believe they are 1/4 inch or t15 torx... If the unit is leaking that bad before tearing apart carefully run your hand around the lower section of the door boot (rubber) and inspect for a tear or a hole Hope this helps you out GOOD LUCK
Posted on Sep 04, 2010
Have old Maytag dryer that does not get as hot as it used to. Takes a long time to dry. Burner does come on. Have determined that vent is clear.
How old is this one? If it is a real old model with 2 belts, it could be the blower belt is slipping.
Jan 06, 2010 | Maytag Dryers
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Apr 11, 2009 | Admiral AW22 Top Load Washer
Replace belt on kenmore 500 series dryer approx 20 years old
that belt part number is 341241. Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way.Use the belt routing diagram found HERE.
Jan 18, 2009 | Dryers
Leaking top-load Maytag - Model # LAT8426AAE
are there 2 screws at the bottom if so remove them and lean out the bottom of the panel . No screws you push 2 clips right under the top on the front with a putty knife or such . Now remove the 2 5./16 screws from front. Please keep up the exchange till we fix it and then rate me fixya
Dec 15, 2008 | Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Fisher paykel intuitive eco
lean it back against the wall pump twist locks into bottom of tub..or pull the small plugs under each side of lid and remove the 2 phillips screws top lifts up
Jun 03, 2008 | Fisher Paykel Eco IWL16
Leaking system frother
Is the frothing wand completely screwed in? You can actually unscrew it (or partially unscrew it) by moving it slightly when you're cleaning it. Twist the black tip, at the very bottom, and you'll find that you can screw it on & off. Make sure it is screwed on tightly & it shouldn't leak.
Nov 22, 2007 | Nespresso D150 Espresso Machine
Kenmore HE2 Plus Front Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
