Question about General Electric Profile PDW7980NSS Stainless Steel Built-in Dishwasher
My Ge Profile, keeps popping the break when I hit the start button. I checked the wiring and connextions and they all look good. Where should I look next?
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Posted on Jul 26, 2010
GE Profile Artica no display
I would inspect the wires that are located at the bottom left freezer hinge, opening and closing tends to break the wires over time. crimp the broken wires into a sleeve type connector, there will be little to no slack to use wire nuts. If the wires are perfect, you might need a new display board, but the wires are the prime suspect...
May 02, 2016 | GE Profile PSI23SGR Arctica¿...
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
The dryer will not turn on when you hit power button or touch screen
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 18, 2010 | GE Profile Harmony DPGT750EC Electric...
Jul 26, 2010 | GE Dishwashers
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
Feb 21, 2009 | GE Profile PFS22MBS Bottom Freezer French...
Hello, My GE Profile dryer model DPXR47EW0WW serial TV771164A has stopped heating. What should I be checking? Thanks, Bob
open it up - take the drum out - the heating element is there - check the wire for breaks - then there are three fuses - if the heating element does not have any breaks - take the fuses to a parts store and have them checked.
Jan 24, 2009 | GE Profile DPSB619ED Electric Dryer
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
General Electric Profile PDW7980NSS Stainless Steel Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
