Question about Frigidaire Ovens
THE BAKE DOES NOT WORK BUT EVER THING WORK - Frigidaire Ovens
    Problem Solver:
  • 14 Answers
You will need model # to get More info, sounds like clock/ timer/oven Control
Posted on Sep 04, 2010
On bake only the bottom element is working
Usually on bake only the bottom element is used. Without a make and model number the only thing I could suggest is that the icon is confusing.
Jul 06, 2016 | Ovens
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
What could be the problem when i put the oven on broil every thing is ok the top element come on ,but when i put it on bake only the bottom comes on
Hello, W/D here.
That's the way it is supposed to work. The top element comes on only for broil, but not for bake, and the bottom element comes on for bake, but not for broil.
Best regards, --W/D--
Feb 22, 2011 | Maytag Ovens
Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Broil element just warm, bake element not working
Hey -have ya tried checking the power block on the back of the stove? This is the first thing I check when power appears to be uneven. Connections may be loose enough to disrupt power flow to the elements. If wires look good, the next step is to find out if the bake element has failed. From the back you can see the wires that attach to the element. Disconnect and check resistance.  should be around 17-19ohms. If not replace with new.  Please acknowledge this post if the info was helpful. Have more if needed  Thanks-- Ed
Mar 20, 2010 | Moffat Ovens
Bake function not working
This problem could be caused by a number of things. The first place to check would be the fuse or breaker panel inside your home, also if your stove has any fuses on the top panel you may want to look at those as well. The next possible problem could be coming from the selector switch that selects bake or broil. However not all oven have this, and is controlled by a oven thermostat, this could also be the problem if the baking is taking too long or burning food. Of course the next possible problem could be that the bake element itself is faulty and will have to be replaced. You can test the element yourself by unpluging the unit and then simply put a volt meter on OHMS and test for continuety or resistance within the element connections. This will tell you whether or not you will require a technician for further diagnoses.Hope this helps
Thanks.
Dec 09, 2009 | Ovens
The bake on my oven does not heat up ? what's the problem
Hi and welcome to FixYa.com!
First thing to check is the bake element. Examine it for signs of blisters or cracks. If you have a VOM, check it for continuity. It is likely that your problem is just a open bake element. Very common problem.
Hope this helps you and Happy New Year from the FixYa crew!
Dec 27, 2008 | Maytag 30" Built-In Single Electric Wall...
Whirlpool accubake oven problem
Hi All,
I tired the delayed bake work around and it didn't help me.
So, being a trained scientist... I know just enough to be dangerous! Here's what I learned. (imitate me at your own risk. This thing is on a 220V circuit at 30A... you or someone else in your house could get badly killed if you do something wrong. You definitely want to send small children to the movies, or at least to bed before trying this!)
First, I turned the self-clean on for 60 seconds to see if both elemets were working. The broiler got bright red but the bake element didn't. The door unlocked as soon as I shut it off, so I could I touched an ice cube to a few insided parts to see how hot they were. The bottom of the oven was barely warm, but the baking element instantly melted and sizzled my ice cube.
Good enough for me: Both heating elements are working, so it must be a controller problem.
Next I turned the power off at circuit breaker, and double checked that the oven was dead. I pulled it out of the wall and removed the top sheet metal cover. Inside I found a red plastic envelope containing a "Tech Sheet". It has a schematic diagram, plus a table that explains the error codes and what to do about them. Be sure to read all the dire warnings and the bit about "For Service Technician's use only" before deciding that you are foolish enough to do anything with it. :-)
I undid and inspected the connector for the printed ribbon cable from the keypad to the controler circuit board. (I happen to know, being a scientist, that 90% of all problems in the universe are caused by bad contact) I didn't see anything obviously wrong, so I reassebled it carefully, making sure the ribbon was fully seated.
I then powered the thing up. It said PF for power failure. I pressed cancel for 5 seconds and it said F0E0 which means no pre-existing fault was detected.
I then pressed bake, and lo and behold the damn thing baked! :-)
I'm not certain it was bad contact, since the other 90% of the world's problems are caused by software. It's entirely possible that power cycling was this thing's idea of CTRL-ALT-DEL. Maybe someone can try flipping the breaker off for 10 minutes without taking anything apart, to see if that clears the problem?
I also have no idea how long this will stay fixed....
Has anyone tried calling Whirlpool? 1-866-698-2538, M-F, 8 am - 8 pm Local Market Time, Sat. 8:30 am - 5 pm Local Market Time, according to their website.
Stay tuned... if I'm not back, the thing is still baking... :-)
Apr 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
