Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
The light on unit will not come on.
I'm not sure if the unit works. I am using WIN Vista and not sure if there is a driver upgrade needed or if I purchased the wrong unit. I purchased Hi-Speed USB 2.0. What should I do?
  • 3 Answers
In order for me to get it to work, i had to change the jumper settings to cable.
Posted on May 29, 2008
  • 35 Answers
Hi kleon,i wonder if u have used any usb device earlier?if not try locate the usb device in your bios is set to disabled set it to enable.hope this works.have a nice time.
raj..
Posted on May 12, 2008
Base system missing
Is this in Device Manager? Did you notice this after the Win 7 upgrade? If so , it's a common problen when upgrading, Is that the only issue? Your Card Reader work? Modem? Co-processor? I have a HP Pavilion DV9320us I loaded Win 7 64bit Ultimate on with similar issues, modem, co-processor, card reader, etc. Use the Win Vista drivers, modify the drivers for Win 7. HP drivers found here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3548477& AND change compatibility of drivers , This will give you the general idea: http://www.techsupportforum.com/4478-installing-a-device-driver-under-compatibility-mode-in-windows-7/
Jan 08, 2013 | HP Pavilion DV9610US Notebook
Software upgrade
Hi!
Well, win xp is absolutly more fun as OS then win 2000:)
To upgrade to win xp will be no problem since Toshiba have drivers for ir. To upgrade to VISTA will...or can give you problem since there arent any drivers for that Tecra S1.
If u deside to upgrade to win xp, here is all the drivers u gona need to do it:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380605&rpn=PT831U&modelFilter=S1&selCategory=3&selFamily=1073768664&selModel=380605%7CPT831U
Good luck
Dont forget to RATE me
Nic
Mar 12, 2009 | Toshiba Tecra S1 Notebook
Gateway mx 6421 win764 driver issues
You could, drivers are based on manufacture. Like Realtek is a common maker of audio chips, and sometimes distributors use a popular motherboard.
You may have plateaued at Vista, by try the Troubleshooting Compatibility with Vista 64 drivers before you roll it back.
BTW - This happened to me with Win 8.
Oct 26, 2012 | Gateway MX6421 Notebook
I downgraded from vista to xp and now i need a sound driver compatible for my gateway:w34oui
This is another tough one.
Since GW does not have Win XP drivers available for your system, it will be difficult to find a sound driver that will work. You could try to use the Vista driver, but I would be skeptical that it will work to use that driver because of the way that sounds are processed in Vista/Win 7.
You didn't mention why you did the downgrade, but if it was performance related, Win 7 should work fine with your system. If there was a certain program etc., that you need, there is another option.
There are many USB soundcards that will will work well with Win XP, and they should not have the XP problem since their hardware is designed to work with XP. Note: If you go this route, make sure you choose one that is Win XP compatible. One other thing on this option, though. Your internal speakers may not route sound through the USB soundcard, which would mean then that you would need external speakers to get sound. I understand that may be a deal-breaker, which is why I would (unless you specifically need XP) either go back to Vista or upgrade to Win 7. Some version of Win 7 feature "XP mode" which allows you to run programs in a virtual Win XP environment. I have not had perfect luck getting XP programs to work, but it's worth a try.
May 25, 2011 | Computers & Internet
How to upgrade window vista to window 7
Upgrade is not suggested,
I would prefer you to install a fresh copy of Win7 on another partition on your PC's harddrive using a Win7 install CD or from a medium (Harddisk, USB device etc)
Why, because your Vista is in perfect working conditon I guess so, so why spoil it.
Many of the hardwares you use in your PC currently (like printer, webcam etc) work fine now.
But when you install Win7 they will need new drivers for it to function perfeclty and I am sure you'll have diffculty locating them.
So i suggest you keep your exisiting Vista and keep using it for your day to day work.
Install Win7 on a new partition and try to get used to it while installing all required drivers and softwares for them to function.
Once your Win7 is perfect then you can slowly SUNSET Win Vista.
Nov 18, 2010 | Computers & Internet
After upgrade from Win Vista, the screen dont work on Win 7
One word DRIVERS. This is ya whole problem... simply Win 7 doesn't have the correct drivers for your PC. Unless ya have the correct drivers ya gonna always have problems. Find suitable drivers for everyone of your devices and store in a Directory, when you install, then, ya will have the correct drivers and hopefully Win 7 will install fine. Remember also Drivers can be installed in "Computability Mode" for XP SP2. Otherwise stick with Vista?
Jan 26, 2010 | Computers & Internet
Error message on Canon scanner -there is a twain error, device might not be connected. I am using Windows 7 Home Premium recently upgraded from Vista Home Premium. What do I need to do to be able to use...
Was it all working OK before you upgraded from VISTA? If yes this sounds like a driver problem. Visit the cannon site and download their latest drivers for Win 7 - that is if there are any yet. As an early adoptor of Win 7 you can expect to have issues with hardware drivers where manufacturers have not yet developed them for Win 7. Once Win 7 has been out and about for 12 to 18 months most manufactures will have caught up and issued new drivers.
Nov 18, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
56 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
