Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
How to remove radiator from 6620 combine - John Deere 6300,6300l,6400,6400l Tractor Radiator
How to remove radiator on 93 model Winnebago Brave ?
I don't know but I have spent a lot of time working on coachbuilt and fixed cab forward control commercial and passenger vehicles.
Usually radiator removal isn't easy on such vehicles as they have to be withdrawn from underneath.
Often the radiator is much taller than the vehicle ground clearance so a hoist or inspection pit is needed Jacking the vehicle and placing it on stands is unlikely to be satisfactory.
The work of removing the various fasteners and hoses is a combination of working inside the engine compartment and from the underside and long arms and short wrenches are the only combination that will work.
Usually the radiator cooling fan cowl must be released from the radiator and pulled back to the engine clear of both radiator and fan. Some cowls are sectional and can be removed piece by piece. Often the cooling fan will need to be removed and access is usually possible after releasing the cowl.
The lower mounting of large radiators is usually very substantial and often constitute a removable crossmember and the radiator must be securely but temporarily supported while this piece of ironmongery is removed.
After everything is ready for removal it would be unwise to proceed further without an assistant or at least taking the precaution of covering the radiator core with strong card or thin board or even sheet steel to protect it from damage. It is also wise to plug the hose outlet at the bottom of the radiator to save the guy underneath getting splashed with coolant.
I hope this gives you a rough idea of how things will probably proceed...
Feb 02, 2015 | RVs
Location of radiator thermostat
The engine thermostat is within the combined upper radiator outlet hose with the engine, remove the cover of the hose outlets combined. thereof within the thermostat
Oct 29, 2012 | 1999 Toyota Sienna
John deere turbo 6620 combine
Keep busting the bearing hanger on the shaft with the variable speed pulley that runs the cylinder.It is the motor side of the machine and my only guess is the shaft is bent.
Sep 23, 2010 | Computers & Internet
What tools do I need to remove a radiator out of a 1996 chevy cavalier?
To Replace a Radiator check this procedure...
Tools:
1. Combination Wrench Set
2. Screwdriver
3. Flashlight
4. Cooling System Pressure Tester
5. Needle Nose Pliers
6. 3/8 in. Drive Ratchet
7. Socket Set
Supplies:
1. Coolant
Steps:
1 Open the hood and locate the vehicle’s radiator.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
2 With the engine off and cold, remove the radiator cap.
3 Place a drain pan under the radiator. Remove the drain plug or remove the lower radiator hose to drain the cooling system.
o Tip: Twisting the hose or using a screwdriver may allow easier removal.
o Tip: Lifting the vehicle will give better access to the lower radiator hose.
4 Remove the upper radiator hose.
5 Remove the radiator fan shroud or remove the electric cooling fan assembly.
o Tip: Transmission cooler lines will need to be removed when replacing the radiator.
6 Remove the radiator.
o Tip: Some older metal radiators can be taken to radiator repair shops for repair.
7 Install the new or repaired radiator. Make sure it is aligned.
8 Install the lower radiator hose and clamp.
o Tip: Replace the hose and clamps if necessary.
9 Install the radiator fan shroud or electric cooling fan assembly.
10 Install the upper radiator hose and clamp.
11 Fill the radiator and radiator reservoir with a 50/50 mix of coolant and distilled water.
12 Install the radiator pressure tester and check for additional leaks.
13 Re-install the radiator cap and start the engine.
14 Monitor the engine temperature.
o Tip: DO NOT allow the engine to overheat.
15 Road test the vehicle, maintaining supervision over the temperature gauge.
16 Verify repair by inspecting for leaks or overheating.
Good luck; remember comment and rated this help.
May 28, 2010 | 1996 Chevrolet Cavalier
I lost my hp deskjet 6620 disc and the computer i need it on is not hooked up to the internet. what can i do?
Download the software on a computer that is connected to the internet and transfer the file(s) via a flash drive or via your network (if connected to a LAN).
Dec 30, 2009 | HP DeskJet 6620 InkJet Printer
I need screws for my nokia 6620
get a nokia scrap phone and remove the screws from it and use it....
Sep 20, 2009 | Nokia 6620
I have nokia 6620 model and it is working only with airtel
Your Nokia is now completely locked to the network of Airtel. You have to take it to the service provider to unlock it. Thank you Sir, Have a nice day.
Sep 19, 2009 | Nokia 6620
Hard reset nokia 6620
Turn off the phone
Press 3, * and the green call key together whilst turning on the phone.
It will ask if you wish to reset to factory defaults (this will erase ALL data from the phone), just follow the onscreen prompts.
The default security key is 12345, hope this works for you.
Mar 20, 2009 | Nokia 6620
Fixing 5-way joy stick.
no way only the center button acn assign a function . other 4 keys can be only used while using menu or gaming functions u can change the application selection for center button in seetings> phone
Dec 04, 2007 | Nokia 6620
Updating Nokia 6620 firmware.
u first of all need a software called nokia software updater which can be doenlaoded from nokia.com and a high speed broadband internet connection . ur system must have atleast 512 mb of ram for doing this connect ur phone using data cable . the software identifies ur phone and says whether there is any update for nokia phone connected then if it s true it willbegin update . CAUTION : first of all make sure dont remove the phone from usb until update is successful. a pwer suppl y failure also must ne fatal
Dec 03, 2007 | Nokia 6620
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
385 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
