Question about Dell 5650 Computer Speakers
I have the Dell 5650 Computer Speakers..I had to reolad the audio driver.. now, the two fron speakers and the center speaker under the monitor work, but the two rear speakers are not producing sound..I went into the control panel audio set up and the slider bars are all present...if i lower the volum eon the fron speakers and increase the volume to the rear, no sound ..any ideas
  • Stan Oct 18, 2010
    i have a sigmatel high definition audio device...
    Problem Solver:
  • 8 Answers
If you are using Sound Blaster, go into "All Programs" and open the "Creative File" and then the "Audio Console", left click the "CMSS 3D" tab, under the "CMSS Modes" click on the selection box and select "CMSS". They should start working at once.
Posted on Sep 30, 2010
Dell 5650 speaker issues
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Dec 22, 2011 | Dell 5650 Computer Speakers
My left side speaker is not working. I plugged in another speaker to the sub output (the plug not working) and got nothing, which proved to me that the speaker wire and speaker itself is not faulty. ...
could be the sound card or its driver. Check your sound properties and make sure the correct set up is selected like 2.1, 5.1 adn 7.1. Verify that the volume levels are balanced, and if nothing helps, reinstall the video driver first. If this does not resolve it, might be a good idea to test the speakers on another system just to confirm they are all ok. If that works, you may need to get a new sound card, or test the card on another computer if possible to confirm if it is at fault. Hope this would be helpful to you.
Oct 14, 2010 | Dell 5650 Computer Speakers
My mms 5650 speakers are for whatever reason not being recognized by my Dell Dimension 8400. I've already made sure my audio drivers are up to date and there are no drivers for these speakers. There is...
Be sure that you have not "muted" your computer's audio-output.
Open the audio "mixer", and check that the "line-out" mix has not been pulled-down to a 'zero' level.
Try the speakers in some other (desktop or laptop) computer.
Try different speakers in your computer.
Check that you're plugging-in to the (green-coloured) "line-out" socket on your audio-adapter (not the blue-coloured "line-in" nor the pink "microphone-in" sockets).
There _are_ limits to what the "Plug-and-Play" features of Windows will detect. Generally, speakers are *NOT* listed within Device Manager.
Try switching from '5.1' to '2-channel-stereo', just to test it.
Jun 28, 2010 | Dell 5650 Computer Speakers
I have the Dell 5650 Computer Speakers and first 2 of the speakers stopped working and when i reinstalled the speakers again none of them worked. the green light of the center doesn even light up, any...
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
Feb 03, 2010 | Dell 5650 Computer Speakers
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
Dell 5650 Speakers on Gateway DX4200
the speakers should have a stereo jack on a wire which would be the out put, if it is a surround sound speaker system then it most likely will have a few wires, if your computer has only one stereo jack input then the green cable would be the one you would connect in most cases, if it has 3 or 6 then you would follow the colour on the jacks and match them up with the input on your computer. if you have done all this and doesnt work check if there is audio icon in the bottom left task bar and if you can use other speakers, if you can everthing should work, if not then check for drivers online.
Feb 10, 2009 | Dell 5650 Computer Speakers
Driver
there are no drivers for the speakers, you need an audio driver installed for you sound card.
http://support.dell.com
Your system will either have an on-board sound card (Sigmatel normally) or a soundblaster expansion audio card. (If the audio jacks are in an expansion slot below the video card, then you have a soundblaster.
Soundblaster drivers are found at http://www.creative.com
Jul 16, 2008 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
221 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
