Question about Kitchen Ranges
I have a Makita G5710R Generator, it was given to me as a hand me down I want information about it.
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
Posted on May 31, 2009
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
Nov 18, 2015 | Makita Electrical Supplies
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
Auto idle does not work propertly on makita g 6101 generator
The battery charging is also a load. If the battery is not well charged or old it may need about 60 - 120 W to charge, which is not "Idle".
Jun 24, 2010 | Makita G6100R 5800 Watt Generator
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
May 05, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Makita Generator no power
Hi Laurence,
Hope you had as good a holiday as I did :-)
Yes the squareish thing in there is a kind of voltage regulator. More correctly, your brushless generator is using this capacitor to regulate output voltage by means of a resonant circuit between a winding on the stator and this part. The short answer is that you more than likely need a new one and because of its particular shape the only realistic source of the new one is Makita.
I disagree with the service tech about the testability of the thing, my Fluke 112 DMM has a capacitance function that would let me tell if your capacitor was shorted ( 0 mfd reading), open (infinate mfd reading), or some value that could be compared to whatever "known" one was applicable. In this case I'd take a loose guess that the reading of a good one is something like 20 - 100 mfd, but that's just a guess.
let me know if the new capacitor doesn't get it,
Carl
Dec 31, 2008 | Coleman Powermate Powermate 5000W...
Kitchen Ranges Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
