Question about Wolverine 4160 Fingerprint Secure 160GB Portable External Drive 160 GB USB 2.0 Hard Drive
When I click on fingerverify I get the following error - "Error performing inpage operation"
Pen drive is inaccessible,says error performing inpage operation,unable to format or open or copy anything
Check whether there is any antivirus or similar program installed which is preventing the writing into the pendrive.
Jan 21, 2014 | Computers & Internet
Access denied, error performing inpage operation
Click Start, Click RUN and type cmd and Enter. You'll be in command window - then type chkdsk [drive:] /F (such as - "chkdsk e: /F") which should perform a repair. It will probably require a restart. Do not touch the keyboard during restart.
Jan 02, 2014 | Seagate Computers & Internet
Had blue screen on laptop took advice and put laptop hard drive in Samsung drive enclosure My desktop can see the drive but I just get the message 'error performing inpage operation' Does this mean my...
Click RUN and cmd then you'll be in command window - then type chkdsk [drive:] /F (such as - chkdsk e: /F) which should perform a repair
hope this helps
Dec 04, 2010 | Samsung HM060HI Hard Drive
Laptop hdd show error performing inpage operation
use reginout to clean up ur system, fix your registry problem , defrag your drive, it may solve your problem
Aug 20, 2010 | Compaq Computers & Internet
E: is not accessible Error performing inpage
dirve e not open there is problems of error performing inpage
Mar 10, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
V:\ is not accessible Error performing inpage operation
To expand upon what ikkenom said, this will work much better done from the command line.
(Assuming Windows XP)
Click "Start", "Run...", type "cmd" and click [OK] or press [Enter]. From the command line type "chkdsk V:\ /F". You can optionally include the "/R" option to check for bad sectors on the disk (Be patient, this will take a long time, especially if there are bad secors).
If this fails, add the "/X" option. This dismounts the volume before proceding. You may need to reboot afterwards before examining the drive.
A MS article describing this error implies that is is likely a physical disk error and the technical reason why the error mistakenly implies a paging fault: http://support.microsoft.com/default.aspx?scid=kb;en-us;141117
I know how distressing it can be to loose pictures and video you've worked so hard to acquire/produce. Good luck!
May 31, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
"Error performing inpage operation" - External drive
hi
run this command from command prompt
Administrator>chkdsk e(your drive letter): /F
if problem persists just post your problem again..
as soon as possible you problem will be solved.
have a nice day
May 19, 2009 | Iomega Computers & Internet
Maxtor 80GB External HD
1. I need to know the brand name , model number , or motherboard you have
2. I need to know what operating system you are using
and when you say open , in what manor do you mean open , in what way are you attempting to open the drive and with what program , so far it looks like you may need to reinstall the computers operating system from scratch , because something is dead wrong , and it looks like a file system error , as if your computer operating system is no longer able to access files properly.
I consider your situation unresolved at this time untill you can give me more information.
I'm trying to reach guru status here in order to help people like you in a far more proper manor.
together we can solve it.
shalom
Aug 05, 2008 | Maxtor Hard Drive
I've just fixed the problem of error performing the inpage operation by using old DOS command CHKDSK <driveletter> /F. And, i'm satisfied with the MS-DOS command.
Jun 18, 2008 | Computers & Internet
Wolverine 4160 Fingerprint Secure 160GB Portable External Drive 160 GB USB 2.0 Hard Drive Logo
136 people viewed this question
Top Wolverine Computers & Internet Experts
David Payne
David Payne
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
