Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 I cant get the cpu to go online, so I cant download, Is there a way to down load to a flash drive and transfer it to my dell??
    Genius:
  • 1,226 Answers
Yes...you can do that..You should download it to the connected PC in the net and transfer it later.
Posted on May 12, 2008
Tip
Service manual for Dell inspirion 1100, 5100, and 5150
Hello,<br /><br />Download the service manual for Dell inspirion 1100, 5100, and 5150 by simply click the below link.<br /><br />Note that the manual is in PDF format, so you need to have Adobe Acrobat reader already installed on your computer.<br /><br />Also, your computer configuration speed will determine how fast the service manual will load. Wait for the service manual to load completely before scrolling in order to avoid it hanging.<br /><br />It is advice able that you print it so that you can have a hard copy. Its usually strenuous reading from the computer.<br /><br /><a href="http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF%20">http://www.elhvb.com/mobokive/edwin/laptops/dell/INSPIRON/1100-5100-5150/1100-5100-5150.PDF</a> <br /><br />Good luck.<br /><br />
on Dec 28, 2010 | Computers & Internet
Dell 5150 won't load drivers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Jul 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Black sreen with flashing underscore
Try pressing "esc". If it doesn't help call the dell technical support hotline. Or ask the shop.
Good luck
Jun 26, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
I have a dell dimension 5150 desktop problem; turn off after 60 minutes working.
Hi, maybe he was over heating, open your tower and look the fan of your CPU and POWER SUPPLY. Did they work? If yes, did the dirt on the heatsink of the cpu hide the heatsink? If yes clean it and make a test!
Oct 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can not download drivers!!
Do you have the original CD's that came with the unit? they are blue and are the recovery cd's. they have all the drivers. Also, the windows 2K and XP OS may have a compatible driver. They reinstalling that driver. or do you have a modem? If your unit didn't come with one then you can purchase one cheap and dial up to the support.dell.com
May 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
Alun Cox
