Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Hitachi rear projection tv 50UX22b
My hitachi rear projection tv won't go on
  • yukz71 Sep 21, 2008
    same for me, I took back panel off and could only find 2 fuses(both appear fine). There is a red LED in center of board that does light up. When you press the power button it makes a click sound on circuit board, then you press it again it makes a slightly different click sound, they alternate.
  • 42 Answers
Symptom: DEAD
Cause: CHECK I402-IS05-I601
The full repair manual can be found HERE!
Posted on Jan 17, 2009
Blue off to right outlines everything
The convergence amplifier IC responsible for blue alignment needs to be replaced. This is not an easy repair. Most reputable tv shops charge between $200 to $300 for this repair.
May 07, 2009 | Televison & Video
Hitachi model 50UX22B turning off on its own
The TV is in shutdown. The red LED is the shutdown indicator. Check fuse E994. If its open, the TV will need the deflection P.C.B. replaced. Its probably not worth the repair costs. These sets also have had problems with the voltage regulator circuit, requiring replacement of the regulator IC at a more reasonable cost.
Feb 13, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50UX22B
Look inside the lens while the set is on. If you see things floating around inside the glass, the fluid will need to be changed inside of each tube. I will post a link on how this is done if this is a Magnavox TV set. Good luck
Feb 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 50UX22B
was it blurry before you cleaned?
you should use lens cleaner and a soft cloth on the lens.
TV: Viewing Screen RPTV - damage and maintenance
Jan 16, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50ux22b has dark screen and general CQ adjustment issues
is the convergence off?
bad convergence amp ic's
Jan 05, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi broken lenticular
It's available on Hitachi but very expansive cuz is coming with fresnel like assembly..
Part number KR00272 - 870$.
Dec 11, 2007 | Televison & Video
Hitachi 50UX22B Convergence Problem
there is a company called pts that will rebuild the board for u just send it in the will repair it and send it back , alwways use your wristground strap.
Nov 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
