Question about Yamaha RX-V420 Receiver
Yamaha RX-V420 No power
This receiver died on day. I have checked the fuses and they are fine. There is power to the power supply board. The standby transformer has the correct voltage, the main transformer has no voltage on the output. But when you press the power button, nothing. No lights, no clicks nothing. Anyone with any ideas? Any checks i can do?
  • 1 more comment
  • bambang_wid2 Nov 06, 2008
    I have the same problem and same indication with my Yamaha RX-V2090.
  • Anonymous Nov 22, 2008
    liugygçliuglboihç;o
  • dude998866 May 11, 2010
    I have the same unit with the same issue. I checked the voltage across the small trans former on the power board (which I assume is the standby power feed) and on the side with two terminals I could only read 0.5 volts accross them Is this within spec? if not what should I check next?
  • 4,234 Answers
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Oct 10, 2009 | Yamaha RX-V750 Receiver
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
Possible burnt out power supply on Yamaha RX-V557
Can you check the power transformer, voltage & resistance.
You may have to unsolder some components to test them...such as the rectifying diodes and the transformer.  I believe that the outputs from the power supply board are all DC voltages.  Is there all so a IC chip on the power supply board?  Does your insurance cover lightening damage?
Mar 25, 2009 | Yamaha RX-V557 Receiver
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
TURNS ON BUT NO SOUND
if the amplifier integrated circuit is busted that will not sound even the power will display the front panel.
Sep 13, 2007 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Apr 26, 2007 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Receiver Logo
491 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
