I have an infocus X1A projector (old) and a Macbook pro with OS X v 10.5.8. Both are on and I got the firewire VGA adapter. When I plug the projector into the laptop it doesn't recognize the projector at all. The projector works on other PC laptops and the Macbook pro recognizes all other fire and usb sources. please help. this is for a charity event.
  • 95 Answers
SOURCE: Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Posted on Nov 20, 2007
SOURCE: USB device not recognized on my VP-D371i Samsung digital camera
i am also have Samsung VP-D371i if u need help my icq number is 400 952 967, but my Samsung VP-D371i do not support usb iam use other line
Posted on Apr 25, 2008
Jidza
  • 24 Answers
SOURCE: Unsupported Signal. Adjust your PC output
Boot into safe mode or VGA mode and reduce the resolution to 800 by 600 and set the refresh rate to 60. After this, reboot normally and check the box to have your video to display only the settings that work for your system, and choose the desired resolution, and refresh should be 70-85 to reduce flicker. Appears as tho your video card is set too hot for the monitor.
MORE: In safe mode or vga mode you may not be able to adjust the settings. Fine. After a reboot, you may be able to start normally and the vga settings might still be there (640x480). Then you can adjust them.
Posted on Jan 23, 2009
damien729
  • 221 Answers
SOURCE: macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Posted on Jun 27, 2009
SOURCE: Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Posted on Jul 21, 2009
What might be the problem since my macbook pro is connected to the projector through a HDMI to VGA adapter, yet the screen remains black?
Vga and hdmi are different formats. Unless you are using a coverter box that translates the data from one format to another it won't work. Vga is analog and hdmi is digital
Oct 08, 2016 | Sharp Office Equipment & Supplies
How can i connect the macbook pro into an lcd projector, which adapter should i use....?
what are your options on the projector side?
Your Mac comes with a DVI (Digital Visual Interface) port.
Attach the DVI to VGA adapter to the VGA connector of the external monitor.
depending on the external monitor/projector, you may need different adapters.
Sep 11, 2010 | Apple MacBook Pro Notebook
What cable(s) do I need to connect a dell 3300mp projector to my Macbook Pro?
HI.... ........YO U NEED A ADAPTER WHICH IS CALLED MINI-DIV TO VGA ADAPTER....THIS ADAPTER WILL HAVE TWO PORTS ONE PORT IS CALLED MINI-DIV PORT ANOTHER PORT IS CALLED VGA FEMALE PORT (WIDER THAN DIV PORT)..NOW PLUG THIS DIV PORT TO YOUR MACBOOK AND THE OTHER ONE IN YOUR PROJECTOR ...YOU MAY ALSO NEED A VGA CABLE..
May 27, 2010 | Dell 3300MP Multimedia Projector
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
Mar 12, 2010 | Apple MacBook Pro Notebook
Is these a driver to get USB connection to macbook
Are you asking if there is an adapter? There actually is an adapter (USB to S-Video) that will work between the two. However, with my MacBook C2D 2.4 GHZ, I use mini DVI to VGA adapter. This allows instant laptop to projector picture and sound. You can use it for anything from powerpoint to movies or even as a giant monitor. The mini-DVI to VGA adapter can be purchased at Best Buy for less than $20. Look for it in the accessory aisle near the Apple machines. IMO, this is a priceless addition to your MacBook. I hope this helps! Please remember to vote if it does.
Jan 27, 2010 | Apple MacBook Pro Laptop Computer with...
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
Macbook recognizes dell projector, but not vice versa
Jun 26, 2009 | Apple MacBook Pro Notebook
Infocus x1a shuts down after 5 minutes
3 red flashing is a lamp error, not the fans. the lamp has a problem striking. make sure it's pushed in and plugged in all the way. if the lamp is not that old, the power supply needs replacing.
Feb 23, 2009 | InFocus X1 Multimedia Projector
Con: Infocus x1 and infocus x1a projector
Hi there
You could most probably do that yes , it's normally only the Mainboard that is different.
Mar 21, 2008 | InFocus X1 Multimedia Projector
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
