Question about GE Profile 21.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22PRBWW
I think my fridge has the snow buildup in the back, i am a single mom, i don't know how to look at this, will you please tell me in simple detail?\r\nThanks!
  • 4,793 Answers
Okay,always start with the obvious.do a full defrost(leave the door open,unit switched off.)DO NOT use any hot water or sharp objects.
clean/syringe out any drain(s)with clorine bleach,(the smell will go in about 30 mins.)wipe the door seals with washing up liquid solution, then wipe over with bleach and rinse off.When the interior of the fridge is dry, close door and check door seals are flat to frame(airtight)then switch on and set to coldest for 24hours.you can fill up with food at any time but make sure all food,bar veg,is covered, to cut down on condensation.then set to +5C for fridge and -18C for freezer.(use a thermometer if you have one)
Posted on Sep 04, 2010
  • kimberlyj_ac Sep 04, 2010
    Thanks you are great!
  • geoff hunter Sep 04, 2010
    I KNOW....
    THANKYOU, I REALLY APPRICIATE YOUR COMMENT.
    PLEASE LEAVE A RATING.
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Maytag fridge model# MSD2561HES
Look inside the freezer for frost buildup on the rear wall. Let me know if there is frost building because that would indicate a defrost problem causing the warm up. Also check your model number because you are the only one on the internet with a model MSD2561HES for the USA Once you have the correct number and answer back about the frost buildup I will tell you each step to take solving this problem which I think is a defrost problem at this point, Thanks Sea Breeze I think your model has the adaptive defrost control board that may be at fault=> 4388932 Defrost Control Board
Aug 19, 2012 | Maytag 25.6 cu. ft. Side-By-Side...
Hi there! My Amana BR22 with freezer on the bottom is not cooling anything. It started last week when I noticed my ice cream was mushy, so I turned the freezer dial higher but it just kept getting...
U need a new compressor for ur fridge, if u go behind ur fridge...there is a black oval shaped unit with gas pipes connected to it. Jot down dtails on the sticker (rating; horse power) and use that data to find a replace. The service man wil have to refill the gas for u too. Please vote if it works, good luck.
Jun 14, 2011 | Amana Refrigerators
Whirlpool Refrigerator model ET18GKXHW0 0 I seem to have a problem with my defrost cycle. The fridge has warmed up over the last few days and there is frost buildup on the back of the freezer...
The defrost cycle is relative to the cooling coils and not the interior temprature. Frost showing up means air is leaking into the fridge... To resolve, you need to observe the cooling coils are free from buildup. it it the coils, usually under panels, that should be attracting the moisture, and the defrost cycle clears that buildup, and not any buildup in the main (user accessable) areas of the fridge....
Defrost timers are not too expensive, consider blindly changing that...but totally defrost the unit around the coils or you will never get past the issue.
Mar 02, 2011 | Microwave Ovens
My steering wheel rocks side to side, and sometimes will feel as if the road is bumpy when its not. what could it be? a simple alignment issue?
Could be many reason for this. Wheels out of balance, wheels bent, worn steering components, tread separation and on.
Sometimes up here we get mud or snow built up on the back side of the wheels which causes the wheel to go out of balance.
If there was no issue or incidence that you can think of that led to the shaking / vibrating I would get it to a shop....don't mess with your front suspension unless you're up for it technically. If there's alot of snow where you are or you were driving a muddy path have a look and make sure there is no buildup.
Take care.
Dec 08, 2010 | Ford F-150 Cars & Trucks
The temp of the fridge has gone up to 18c,an has stoped cooling .what could be the problem .how do i repair it
forst off i need the model number,second tell me what's going on,is there ice or like a snow buildup on the back inside wall of the freezer?if so you have a defrost problem,if the freezer is on top is there ice leaking down into the fridge section,if so you could have a blocked drain,also open the freezer door,do you hear the fan blowing,if not you could have a bad defrost fan motor,send the model number and check some of the things i just asked about and i'll be glad to help you out
Oct 19, 2010 | Refrigerators
A week ago the stuff in the bottom 'veg keeper' was getting too cold so I cut back both the fridge/freezer problem to 'orig settings.) I did put a ton of food in the refrig for Easter (maybe it held the...
it is not defrosting . coil is icing over it will slowly get warmer in fridge then freezer. will be defrost timer needs replacing or defrost element. also listen if fan motor is running when door closed.
Apr 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Fridge is not cool. Freezer has soft ice buildup inside
Your website is fantastic... it really helped me and saved me money!!!
I defrosted my fridge overnight. Cleaned all the water up. Plugged the fridge back in and it works likes new. Thanks :):):):)
Mar 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
10 year old Maytag USA style fridge freezer. Motor running all the time but freezer showing only 0 degrees C and fridge 15C
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Maytag Refrigerators
Fridge runs, but fridge side doesn't stay cold. freezer is totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Mike
Jul 12, 2008 | Refrigerators
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
