Question about Ortho Dial N Spray Hose End Sprayer
I have a Ortho dial'n model 350. The hose connection assembly had come loose somehow and was in pieces when I pulled from its storage place. My problem is I can't fugure out how to put back together correctly. Can you help?
5 Suggested Answers
  • 231 Answers
SOURCE: i need the owners manual for the ortho dial n
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Posted on Jul 03, 2010
kirkx
  • 2019 Answers
SOURCE: using Ortho weed and crabgrass
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Posted on Aug 19, 2010
  • 58 Answers
SOURCE: Ortho 2 gallon pressure sprayer has pressure but no spray
Mix about 1/2 cup of Dawn soap and water half way in the sprayer as it might have a little oil in it from fungicide liquid or anything else with oil content that has been in the sprayer. Once you have sprayed the sprayer for about 10 min. let the soap soak in the tubing for at least a couple hours or overnight is better. Rinse out good and try spraying just water and see if it works. Also,be sure to check for air leaking you should be able to hear it if you put your ear up close to the sprayer after pumping it. Another thing is make sure the handle is in its full locking position. On the side of the tank there is usually a little release valve be sure it's tight and if you find that it is loose and or leaking screw it out nice and easy and wrap some white plumbing tape around it and screw it back in just not to tight as you don't want to ruin the thread on it.
I hope this helps and fixes the problem without having to buy a new pressure sprayer. Good Luck!
Posted on Aug 23, 2010
  • 65 Answers
SOURCE: I need a nozzle for
Sorry to hear about the problems you are having with your Ortho Dial N Spray. Please contact Ortho at 877-465-5160 and we will be happy to help you further.
Hilary @ Ortho
Posted on Aug 29, 2011
I need to replace my container 350-08
It may be more practical to replace the complete sprayer.
Jun 21, 2014 | Ortho Dial N Spray Hose End Sprayer
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I need a nozzle for the Ortho Dial N Spray Multi-use hose-end sprayer. I cannot get an answer back from Ortho on how I can get the part. How can I remedy this situation without buying another Dial N...
Hilary @ Ortho
Aug 29, 2011 | Ortho Dial N Spray Hose End Sprayer
I am confused. Your driveway weed killer says 1 quart per one gallon of water, and the dial n spray has just ounces on the top up to 8 ounces and up to 32 ounces to be filled on the side of container....
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
Aug 21, 2011 | Ortho Dial N Spray Hose End Sprayer
How can i disperse water soluble products like fertilizers
mix first into a slurry then add to ur dial n spray. if product is not specifically for that hose end deal might not work
Feb 01, 2011 | Ortho Dial N Spray Hose End Sprayer
The contents in the bottle doesn't come out
Open the continer is there a small piece of hose connected to the lid if not connect it. the water creates a suction through the hose when it passes over the hole inside the continer to spray the contents of the bottle.
Sep 11, 2010 | Ortho Dial N Spray Hose End Sprayer
Using Ortho weed and crabgrass concentrate... what setting do i use on my Ortho hose end sprayer
Aug 19, 2010 | Ortho Dial N Spray Hose End Sprayer
I need the owners manual for the ortho dial n spray hose end sprayer.
Jul 03, 2010 | Ortho Dial N Spray Hose End Sprayer
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
Ortho Dial N Spray Hose End Sprayer Logo
298 people viewed this question
Top Ortho Garden Experts
raysaw
Nick Olsen
Are you an Ortho Garden Expert? Answer questions, earn points and help others
