Question about Sherwood R-756
I can't get volume for the cable and dvd - only the toner - I punched somethign on the remote but just can't get it.
  • 158 Answers
You might have changed the inputs from digital(optical or coax) back to analog the red and white jacks...see which type of connection your using and assign the reciever to them
Posted on Sep 04, 2010
Need code for apex tv/dvd combo to program remote
http://www.hifi-remote.com/ofa/apex_help.shtml
To program the Apex DVD player on your Radio Shack or One For All remote, there are several steps involved. Basically you will be using the TV device code 0030 and re-mapping all the buttons. There's several steps to get wrong so I will include lots of error checking so that if you make a mistake you will know where you went wrong. Before you start, you should print off the advanced codes.PLEASE NOTE:This will only work for the AD600A model. There isn't a code in any of the current OFA/RS remotes for the newer models (ie, AD500A, AD660A, AD703A, AD800A, etc)
1. Confirm that you have TV code 0030 on your remote.
(Every remote has this code, I am including this step just for your piece of mind, by all means skip it and come back to it if you have problems).
a. Turn on your DVD player and have is displaying on the TV.
b. Press the TV button.
c. Press and hold the SETUP button (the green P button on R/S remotes), wait for two flashes.
d. Type 0030 and wait for two flashes.
e. Press the POWER button, you should see the VOLUME indicator display on the TV screen.
You have now confirmed that you have the TV code 0030.
2. Re-assign the DVD button.
(On the Cinema 7 remote you will probably want to use the DVD button, on the R/S remotes you might want to chose the AUX2 button. In this example when I refer to the DVD button, I am referring to whichever device key you have selected to control your DVD player).
a. Press and hold the SETUP button, wait for the two flashes.
b. Type 992, wait for the two flashes.
c. Press the TV button, followed by the DVD (or AUX2) button. Two flashes.
You have now re-assigned your DVD button to be a TV button, this is so we can enter the TV device code.
3. Assign the TV/0030 code.
a. Press the DVD (or AUX2) button.
b. Press and hold the SETUP button, wait for two flashes.
c. Type 0030 and wait for two flashes.
You have programmed the DVD button to TV code 0030.
4. Program the function buttons.
(You will have to program every button that you intend to use. Don't waste memory by coding buttons that you will rarely, if ever, actually use. If you don't think you will use the numeric keys, for example, don't program them. If you intend to use the volume controls from your TV or amplifier, don't program the volume controls).
I will walk you though setting the POWER button.
c. Type 994, wait for the two flashes.
d. Press and release the SETUP button. (Don't hold it this time).
e. Type 052 (this is the code for POWER).
f. Press the POWER button, wait for the two flashes.
g. Press the POWER button, your DVD player should turn off.
You have now programmed the POWER button. Repeat the steps above for all the buttons that you want to program.
5. Resetting the DVD device.
In order for "volume punch through" to work, you will need to reset the DVD device button to be a DVD button again. This is only an issue for the Cinema 7, because "volume punch through" only works on the original VCR and CBL buttons on the 15-1994, and even then it will only work with the TV's volume).
c. Press the DVD button twice. Two flashes.
You have now reset the DVD button.
6. Setting up the volume controls.
You have several choices with the volume controls. You can program them with the APEX codes, which will invoke the DVD players volume controls, you can use "volume punch through", or you can manually set the volume controls to operate the device of your choice. In this example I will assume that you want to use your stereo equipments volume controls and that the stereo is programmed to the CD device button. Please replace the CD button with the TV button in this example if you want to use your TV's volume.
d. Press the CD button, followed by two presses of the VOL UP button.
e. Wait for two flashes.
You have now programmed the DVD's volume up button to control the CD's volume up function. Repeat these steps for the volume down and mute buttons.
7. Setting up a Loophole Menu macro button.
If you have the version of the Apex that has the "Loopholes Menu", then you might want to set up a button to take you right there. It saves having to remember the secret steps. In this example I am going to put the macro on the "S4" button, but you can put it on any button you like, just remember that it will be in effect under all devices.
c. Type 995, wait for the two flashes.
d. Press the S4 button (or the button of your choice).
e. Press the following buttons in this order (the button names in paranthesis are the buttons that I suggested these Apex functions be assigned to):
STOP, STOP, SETUP (Program), STEP (Move), PREV TRK (CH Down), NEXT TRK (CH Up)
f. Press and hold the SETUP button, wait for two flashes.
It is important to hold the SETUP key until you see the two flashes in the last step. If you release it too soon, the remote will assume that you want the SETUP button to be part of the macro, which will cause some un-expected results when you try using the macro.
Hopefully you have now successfully programmed your remote to handle your Apex DVD player, now you can enjoy movies from all over the world. if you haven't already visited the un-official Apex head quarters, here's the address: www.nerd-out.com/apex.
May 15, 2015 | RCA Universal Remote Control
Need tv code to program remote
May 15, 2015 | Apex Digital Televison & Video
Tv volume too low
Sometimes there is a volume on older cable boxes. Unfortuanately adjusting the volume can be a chore because most cable remotes are volume locked to the TV input. You can try and press the cable button on your cable box remote and see if the volume will adjust, if not I would call your cable company and see if they can help, and possibly replace the box. Usually you can take the box to a store for your provider in the area and they can swap it out.
Apr 06, 2014 | Toshiba 32LV67U 32 in. HDTV LCD TV/DVD...
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
We have to hold the remote control button hard and straight at the reciever for ti to work
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
May 20, 2010 | Yamaha HTR-5860 Receiver
The shaft of the volume control was contaminated with crazy-glue
3. Type 993
Jun 07, 2010 | Yamaha HTR-5740 Receiver
Code for sv2000 dvd to use with direct tv unverisal remote
SV 2000 TV/DVD combo code using the Direct TV Universal Remote
11963 is the code for the direct tv remote. I just figured mine out tonight!!!
1. switch the top button over to tv
2. hold select+mute button till light blinks twice
3. using key pad punch in 11963 and hit the vol up button
4. when the volume turns up simply just switch the top button back to the d-tv.
DONE!
Dec 26, 2009 | Televison & Video
Stuck with progressive scan mode
My dear friend try with this,turn on the dvd take out the disc open the tray now push for 5 seconds the button stop.Good luck.
Jun 18, 2008 | Zenith XBV243 DVD Player/VCR
I hit setup and i clicked something and then my problem occured.
Try pushing the OUTPUT SELECT button on the DVD remote.
This button Cycles through the 3 main output views:
DVD, Tuner and VCR.
Sherwood R-756 Logo
44 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
