TV will not power on-red blinking light-have to pull power chord which is sporadic in it's effectiveness... However, when and if power cycling works the tv then randomly powers itself off and have to do the power cycling process again... Maganvox Plasma model#50MF231D/37...Any suggestions??
  • 5 more comments
  • souza8796 Sep 04, 2010
    I've since changed the 2 10V 3300UF 105C capacitors however, now the tv powers up and stays on but no pic-get lines and no response to anything: channel change, menu, input select, volume,-just get lines-tv powers up fine but now nothing but lines, and I tried connecting to cable box and got a real bad burning smell?? Any suggestions??
  • souza8796 Sep 05, 2010
    Comments Cont'd
    Note: with regard to previous comment~before I changed capacitors I was getting picture and all functionality: input select, menu, volume, channel change, etc. just had the problem of inabilty to power tv on-4 red blinking lights-had to power cycle (unplug) multiple times and then would power up... After reading about other people and their similar issues I changed the 2 10V 3300UF 105C capacitors... Now tv powers on fine but no pic nor access to channel change, menu, input select, volume,-just get lines on screen? Not sure what I could have done-pretty straight forward process with replcement of capacitors and that in fact seems to have been done proper because tv is now powering up but now no pic/functionality? Any idea what may have happened to cause this?
    Thanks
    comment cont'd:
    Also, after changing capacitors I connect tv to cable box and got really bad burning smell-however, don't get smell when I power tv on and not connected to cable box?
    Note: I had prob where tv not powering on-4blinking red lights...with regard to previous comment~I did already change the 2 bulging capacitors?before I changed capacitors I was getting picture and all functionality: input select, menu, volume, channel change, etc. just had the problem of inabilty to power tv on-4 red blinking lights-had to power cycle (unplug) multiple times and then would power up... After reading about other people and their similar issues I changed the 2 10V 3300UF 105C capacitors... Now tv powers on fine but no pic nor access to channel change, menu, input select, volume,-just get lines on screen? Not sure what I could have done-pretty straight forward process with replcement of capacitors and that in fact seems to have been done proper because tv is now powering up but now no pic/functionality? Any idea what may have happened to cause this? Also, after changing capacitors I connect tv to cable box and got really bad burning smell-however, don't get smell when I power tv on and not connected to cable box?
    it was clicking-
    I did already change the 2 bulging capacitors…before I changed capacitors I was getting picture and all functionality: input select, menu, volume, channel change, etc. just had the problem of inabilty to power tv on-4 red blinking lights-had to power cycle (unplug) multiple times and then would power up... After reading about other people and their similar issues I changed the 2 10V 3300UF 105C capacitors... Now tv powers on fine but no pic nor access to channel change, menu, input select, volume,-just get lines on screen? Not sure what I could have done-pretty straight forward process with replcement of capacitors and that in fact seems to have been done proper because tv is now powering up but now no pic/functionality? Any idea what may have happened to cause this? Also, after changing capacitors I connect tv to cable box and got really bad burning smell-however, don't get smell when I power tv on and not connected to cable box?
    I was getting clicking...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
  • 5,807 Answers
On some they replaced capacitors:
3300uf 10V 2 pcs
on the Power Board, One has to check on it.
It could also be from bad MOSFET and/or oscillators.
But try on capacitors first.
Posted on Sep 05, 2010
  • 11 more comments
  • Rommel Cana
    Rommel Cana Sep 05, 2010
    One have to take voltage measurement ( assuming you have replaced
    the capacitor in right order ) .
    there is a 3.3V Regulator, besides the other output voltages.
    post voltages on the connectors so i can help you further,
    just like i said above , it could also be from MOSFET,
    check for fuses , could also be zener diode on other board.
    Although replacing the Power Board does not guarantee
    it will work.
  • Rommel Cana
    4 to 5 Blinks still on the power board one has to look and check on it.
    post voltages so we can establish where the fault lies.
    Post Voltages when the unit is in standby,
    when the unit turn on
  • Rommel Cana
    and use a DVD player as the source or other media player like VCR
    use video Input if you can select Video, protection comes after 3seconds
    when you turn it On
  • Rommel Cana
    after Voltage Measurement , you need to have a service manual
    to properly guide you in right order,
    here is the link,
    Philips/Magnavox - Plasma Television - 50MF231D/37 Service Manual ...
    only with a fee,
    But if you can post voltages, then will try to work these out
    without the voltages applied, no one can never know what is happening on
    your TV circuits.( cause we cant see your unit much as we do not
    know what is exactly your board part number is ) , there are three available
    i just hope yours is having " A "
    your problem could also be on other board, but like i said
    check for fuses , if it is bad, MOSFET's are included .
  • Rommel Cana
    Rommel Cana Sep 06, 2010
    Recheck and triple check your soldered components and post voltages
    on that capacitor .
  • Rommel Cana
    or a possibility of unwanted shorted solder joint,
    How to solder boards properly
    for fuses:
    Troubleshooting
    basic of transistors
    Transistors
    for MOSFET
    How to test MOSFET
    be careful with the MOSFET on your board it is sensitive
  • Rommel Cana
    additional guide
    it also applies to changing capacitor
  • Rommel Cana
    and here is an schematics what a MOSFET looks like:
    these MOSFET "s are controlled by the oscillator
    ( shown lower left side of the image )
  • Rommel Cana
    additional guide
  • Rommel Cana
    more :
    Do you have these Voltages?
  • Rommel Cana
    here additional regulators that you should check:
  • Rommel Cana
    Rommel Cana Sep 07, 2010
    Another alternative ( only to be safe when troubleshooting )
    Use an external Power Supply 12V in lieu of 12V generated by the TV Power
    Supply.
    These would be a lot safer, Measuring Voltages on the Board.
    Although the unit will not come totally on , but the process of
    " Divide and Conquer " Style will help you troubleshoot safely.
    These is just only a tip.
  • Rommel Cana
    Rommel Cana Sep 11, 2010
    i just hope these answers your problem
  • 979 Answers
Hello sir, hi, did you take precaution like putting on anti static wrist wrap? or before touching the main board, did you hold ground to discharge static electricity that may be on your body? when this things happen, damage to the main board is likely. Recheck your work on the capacitors, you may need to isolate the power supply and check for voltage drops across every capacitor. If you have a 3300 uf 10v capacitor, you should get a voltage drop of 10v or less. If no voltage present, go backwards and check where the voltage disappears. Until you find and replace the bad section or part.
Posted on Sep 06, 2010
  • 4,889 Answers
Sounds like a problem with the set entering into protect mode. Any clicking noise before it turns off?
Why dos tv still blinking red with no power
If you pull the plug out of the wall, it should stop. Otherwise it's a reminder that you have switched it off by handset but it is still live. If the TV works ok, ignore it, it is probably just an economy reminder. If the TV does NOT work, you may have a fault on the power supply board. Have you read the manual to see if it mentions the red light?
Aug 29, 2014 | Samsung Un55d6000 55 Inch 1080p Led Hdtv
My Panasonic TH-42PZ700U 42in. TV doesn't turn on anymore. The red power light blinks 7 times. I hold down the power button until it stops blinking. When I let go of the button, the red power light stays...
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
Mar 04, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Green power light on no sound or picture cycles
MAYBE INVERTER BOARD BAD..
INVERTER BOARD IS A PART OF THE LCD PANEL UNIT
Sep 28, 2009 | Sharp LC-32SH12U TV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Aug 16, 2007 | Toshiba 20HL85 20 in. LCD Television
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
