Question about Jenn-Air JGD8130 Gas Cooktop
How do I disable the downdraft on a Jen-Air JGD8130? I purchased a replacement cartridge for the grill and the downdraft fan comes on automatically when either of the left 2 burners are turned on. This is horrible since it sucks the flames to the left and takes forever to cook. I believe there is wiring in the left 2 knobs that need to be disabled. Please advise of the steps to allow me to cook with 4 burners so I can manually turn on fan when needed.
5 Suggested Answers
  • 161 Answers
SOURCE: JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Posted on Jul 01, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
aborcass
  • 2651 Answers
SOURCE: CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Posted on Jan 10, 2009
SOURCE: Switch for cook top fan
I have two 71001494 switches new.
Posted on Feb 25, 2012
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
I just replaced and old '80s Jenn Air downdraft cooktop with a new JED 8430 and the fan blows rather than sucks. How do solve this problem? Its wired the same as the old one with the whitel and ground...
Best off to call a reliable service company such as Sears. If you just purchased it, the repairs will be covered under the manufactures one year warranty.
Feb 01, 2010 | Jenn-Air JED8430 Electric Cooktop
After using the grill cartridge for the first time, and then replacing it with the double burner cartridge again, now the fan goes on every time we turn those burners on. This is a grill only feature. ...
There has got to be an interlock that is actuated by inserting the grill into the cooktop. That interlock switch or sensor is probably stuck closed and still is sending the signal to the stove that the grill is being operated, not the burner cartridge. Pull the burners out, insert the grill back into the cooktop a few times feeling for interference or something not seating right. When you find the interlock or sensor, inspect it to see if it is hung up, clean it, adjust it, or tap it lightly. If the switch/sensor is operating properly, reinsert the burners, make sure the fan is turned off, and operate them, checking to see if the fan is now off. If not, there is either a faulty sensor or a fault in the signal line to the control board or in the board itself. But a hung up interlock is what I would be looking for first. Good luck.
Dec 07, 2009 | Jenn-Air JGD8130 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Dec 31, 2008 | Jenn-Air JGD8345 Gas Cooktop
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
109 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
