Question about LG WD14121 Front Load Washer
My LG washing machine model WD 85290 front loading is having a problem while switch on the machine the electric connection gets trip off\r\nwhat should I do?
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Posted on Aug 23, 2007
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Posted on Jan 31, 2009
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Lg wd 10165
Check the load of clothes in your machine ! Unload it! And turn it on empty! Check if its working ! If yes then reduce the quantity of cloths you are putting in
Oct 15, 2013 | LG Washing Machines
I want to test electric motor for lg WD-80490TP washing machine. how to connect the wires
This is a single phase motor with a capacitor for starting. you can get a lot of info on the link below:
http://en.wikipedia.org/wiki/AC_motor
Jul 22, 2011 | LG WD14121 Front Load Washer
My LG WD-1049C has suddenly starting causing our power to go out and the safety switch flicks on/off. Doesn't appear to be any water leaking out. No error message displayed.
Hi just read your posting.Does your machine trip the power as soon as it is turned on or after it has been on for a time?Usually on the front loaders it is the heating element that trips the safety switch.Have you tried setting the wash temp to a cold wash?Please reply with additional information and I will help you as much as I can.Looking forward to your reply.
Sep 18, 2010 | LG WM-12230FB Front Load Washer
Indesit wd 125 had tripped a fuse switch
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Jul 27, 2009 | Indesit W 123 Front Load Washer
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Jan 06, 2008 | LG WD-16115FD Front Load Washer
LG WD14121 Front Load Washer Logo
42 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
