Question about Panasonic NV-GS230 Mini DV Digital Camcorder
Black horizontal lines on playback. Happened after I tried to dub tapes to a video capture device usung a S-video cable.
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 04, 2010
How to conver analog vedio to digital
you need following Equipment
  1. PC
  2. Analog Capture Card (you can find prices here)
  3. Sound card (some capture cards has their own audio input)
  4. Cables
  5. VHS Player/Camcorder
  6. Capture Software (Windows Movie Maker 2 can do this)
and perform these Steps
  1. Hook up your capture device to your computer
  2. Turn on your PC, install the drivers
  3. Hook up your analog player to your capture card with the cables
  4. Load your capture software
  5. Set the capture options (video and audio)
  6. Start the capture process
  7. Start the playback on your analog device
  8. Once the analog device has finished, press stop
  9. Stop the capture process
  10. Save the video
Remember, you capture card merely records the signals that comes from you analog device. If the footage is blurry and choppy, it's probably because of aged tapes or dirty video heads.
Good luck, do rate the solution if helped
Nov 30, 2010 | Televison & Video
Tip
How to convert analog video to digital format.
<p>Equipment needed <br /> <p> <br /> <p> <ol> <li>PC</li> <li>Analog Capture Card (you can find prices here)</li> <li>Sound card (some capture cards has their own audio input)</li> <li>Cables</li> <li>VHS Player/Camcorder</li> <li>Capture Software (Windows Movie Maker 2 can do this)</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Steps to perform<br /> <p> <br /> <p> <ol> <li>Hook up your capture device to your computer</li> <li>Turn on your PC, install the drivers</li> <li>Hook up your analog player to your capture card with the cables</li> <li>Load your capture software</li> <li>Set the capture options (video and audio)</li> <li>Start the capture process</li> <li>Start the playback on your analog device</li> <li>Once the analog device has finished, press stop</li> <li>Stop the capture process</li> <li>Save the video</li></ol><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p>Remember, you capture card merely records the signals that comes from you analog device. If the footage is blurry and choppy, it's probably because of aged tapes or dirty video heads.<br />
on Nov 30, 2010 | Computers & Internet
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
Feb 06, 2009 | Canon ZR60 Mini DV Digital Camcorder
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic DMR-EH50. Dubbing NTSC VCR tapes to HDD
That's normal with different region signals. Only a multiregion recorder/player combo will transfer properly
Jan 03, 2008 | Panasonic DMR-EH50 DVD Recorder
Playback
Not really a solution. But I find a bit of blank tape and record for a few seconds. Stop rewind and for some reason it clears the black lines. Until the next time. Pain but it works for me.
Jimmy
Dec 23, 2007 | Panasonic NV-GS11B Mini DV Digital...
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic NV-GS230 Mini DV Digital Camcorder Logo
103 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
