I need the installation manual for a Marco model 792776E fireplace with blower assembly
SOURCE: marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Posted on Jan 28, 2009
SOURCE: need instruction manual for style
i do not have the manual you need but if you can direct me to a source for this blower i'll forward the manual to you later
Posted on Feb 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
Posted on Feb 09, 2009
  • 297 Answers
SOURCE: I have a marco firplace model 7927740 no manuel..need to know how
the lever is the fresh air port to outside.
Posted on Jul 15, 2009
  • 3238 Answers
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Posted on Feb 25, 2010
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Where does the FBK200 blower go in the Marco fireplace
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Feb 25, 2011 | Heating & Cooling
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
Marco fireplace Model#792775D Instruction manual
Ok, I have a Marco Model 792775D. I am renting the house and there is no manual for it. How would I use it. Is it supposed to be fake logs or is it for real logs. The land lord said he didnt know if it works. I need a manual for it. PLEASE HELP!!!
Oct 23, 2010 | Heating & Cooling
Dec 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
