Question about Jenn-Air JED8230 Electric Cooktop
Downdraft fan won't turn off - Jenn-Air JED8230 Electric Cooktop
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
Jenn air downdraft fan 2e speed doesn't work
Probably the switch or a burnt out resistor.
Mar 18, 2014 | Cooktops
Downdraft fan switch
please go to web page and fix it:
http://www.ehow.com/how_8733070_troubleshoot-ge-gas-downdraft-cooktop.html
God bless you
Jul 14, 2012 | Cooktops
No gas on viking professional. ignitor works downdraft does not
There are solenoids that turn the gas on to a burner. If they're bad it won't supply gas to the burner. There is also a mother board on that model that could also be the problem. When it comes to this brand it's difficult to diagnose without being there. If the downdraft is not working then I would guess that the mother board could be the problem...sorry I couldn't help more.
Aug 27, 2011 | Viking 37 in. VGSU163-6B Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Fan has difficulty turning, buzzes
Hi
Tha model is a Maytag.
There are a few things to check here, and it's best always to use the proces of elimination.
These are the things you need to check:
1.MOTOR, DOWNDRAFT
2.BLOWER ASSEMBLY
3.SCROLL, BLOWER ASSY.
4.CORD, POWER (MOTOR)
as you mention before sometime run and sometimes do not run.
youll have to start by checking those items and make sure they are not damage or obstructed. I have some wiring diagrams for that model, if you would like for me to email them to you, please let me know.
I hope that will help you
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Jenn-Air JED8430 Electric Cooktop
DOWNDRAFT FAN MAKES LOAD NOISE
open your cabniet up under the unit you will have to disconnect the venting in this will give you access to the blower section also make sure the filter is not hitting it inside they usally install a screen to prevent this but maybe yours is missing
Jan 19, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
273 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
