Question about Nikon N60 35mm SLR Camera
How do i rewind the film on the nikon n60? - Nikon N60 35mm SLR Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The camera should rewind the film when it reaches the end of the roll. If it doesn't, or to force a rewind in the middle of a roll, press the mid-roll rewind button with a pointed object. The button is on the bottom of the camera, toward the left end (away from the handgrip), and marked with a roll of film.
Posted on Sep 07, 2010
What type of film does a n60 slr camera use
The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
Oct 11, 2014 | Nikon N60 35mm SLR Camera
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Choice of film speed
ISO400 is probably the film you want to go, as higher speed film costs more and have more grain...
Feb 11, 2009 | Nikon N60 35mm SLR Camera
Nikon N60 fEE Issue
First of all, you can download a manual from here.
(http://www.devicemanuals.com/guide/Cameras/Nikon/Nikon-F60-N60-Instruction-Manual-TmpNMU5qUT.html)
Basically, with certain types of lenses you need to set the aperture ring on the actual lens to its minimum setting (f22 or f32). Once it is set here, the camera can then control the aperture. It's covered on page 16 of the manual.
Hope this helps,
Matt
Mar 04, 2008 | Nikon N60 35mm SLR Camera
Nikon N60 35mm SLR Camera Logo
186 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
