Tv. Westing House mod.# LTV-40W1HDC, tv works perfect with cable box, but with dvd player (any dvd) the colors are not good. what is the problem??
  • jaduan2405 Sep 05, 2010
    the problem is different thas just the connections for sure..
  • 10,594 Answers
If dvd player is connected in Component Video input of tv, make sure all three video wires are plugged in respective color pins in dvd and tv jacks like red to red, green to green and blue to blue to get correct color of dvd picture.
Let me know if connection setup is different or you have additional question.
Thanks.
Posted on Sep 05, 2010
  • 10,515 Answers
If this is the problem with DVD player, it seems more of an issue with connectors.I have seen certain problems if you are using S-Video.Try RGB, if your TV supports that, otherwise you have to use composite.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2010
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Is there a way to reset a westing house flat panel tv? It is frozen
call sears they charge $99 to come out free estimate. mine cost $300 to fix, get your estimate and go from there good luck
Dec 19, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Feb 15, 2010 | Westinghouse LTV-37w2 HDTV
I can't figure out how to connect our dvd player to the tv. We also have a cable box and a tivo box. The dvd player has the cord with the red, yellow and white plugs on both ends but I can't figure out...
Look at the back or side of TV you will see AV in with the same colors Yellow, Red, White. Just follow the code and plug your DVD cable accordingly. Remember to switch the menu to AV to see the program.
Aug 14, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I get no picture ...tv turns on bulbs are working but I get no pic with tv or dvd and I cant see the menu or any of its properties .... but I do get sound, Thanks. The lcd tv is a westinghouse 40 inch dvd...
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
GBC_CMC@yahoo.com
Jul 11, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture turns Blue-Gray after 30 min
cheak cables what cables uusing ? thx nick
Feb 07, 2008 | JVC TH-M65 System
Remote control
need to set up a remote control to my tv. I lost instructions and codes.
Nov 11, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
