Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
X box wont start up
X box freezes up when it shows the clock srtting picture
    Sergeant:
    Champion:
  • 417 Answers
CORRUPTED FILES ON YOUR SYSTEM
JUST TAKE IN TO A REPAIR SHOP THEY WILL BE ABLE TO FIX IT FOR YOU
Posted on Jul 02, 2008
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
Can you fit a frost switch to the T10404R
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/PF1102.ashx
http://www.poolandspacontrols.com/products/freeze%20protection%20controls/multi%20circuit%20freeze%20protection%20controls.aspx
Intermatic makes a freeze protection control that wires directly into a 240V timer.
If you already have a freeze control, the wiring diagram might help.
The manual has this image larger.
It shows wiring to connect the freeze control directly to one 240V timer.
Intermatic make a freeze control for 1 or 2 circuits.
Intermatic page showing Pool and Spa timers
http://www.poolandspacontrols.com/products/mechanical%20controls/100%20amp%20specialty%20control%20panels.aspx
Nov 11, 2010 | Intermatic T10404R - Two 220 time clocks...
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
True model gdim-26. runs fine unitl defrost then does not keep cold after defrost.
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Mar 23, 2010 | True 26 cu. ft. Commercial Freezer GDIM-26
TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Sep 27, 2009 | Philips 50PFP5332D 50 in. Plasma...
Camera says "internal memory full"
Goto srtting > storage > set primary storage as memory card.
Jul 08, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Open Questions:
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
24 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
