Question about Homelite Garden
I am tryting to replace a blade on the Homelite Edger UT50901 and I can't get the old blade off
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: can't run the edger for more than 60 second
Hi pqtallbroad...
It sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jul 20, 2011
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
How can I replace broken gas line in my edger
You can buy new gas line at a hardware store. Take the old one off and bring it with you so that you buy the correct size. Cut it to length and slide it back in place. Should be pretty simple fix.
Apr 16, 2012 | Homelite Garden
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Jun 19, 2011 | Garden
Fuel mixture ratio?
Homelite has a lousy website for technical info but most small 2 cycle engines burn a mix of 50:1
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Where can I get an owners manual for the Homelite edger UT13140?
This is not a homelite manual.....but it seems to cover an edger exactly like the ut-13140...I had the same edger, and eventually found this:
http://southlandpowerequipment.com/images/southland%20product%20info/S-WLE-0799/manual_S-WLE-0799.pdf
Nov 14, 2009 | Homelite Garden
Mightylite 26cc Edger
You need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure to clean the small screen in the carb. as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
Mar 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
62 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
