Question about Acer Computers & Internet
Battery charges quickly but does not hold charge even with new battery
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
Ipad battery wont hold a charge
Time to get a new battery.
Jul 15, 2014 | Cell Phones
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
Kawasaki kz750 spectre...loses charge quickly even on a new battery...what is the problem?
Hi,,you need to replace the regulater/rectifier,,,as even a new battery is not holding a charge.
you will find it in a side panel,or under the tank it is square shaped with fins on it.
Aug 30, 2011 | kawasaki Z 750 Motorcycles
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
LG Dare quickly dying even after a long time charging.
The cells of the battery of your phone is very low that it can no longer hold charge.
All you need to do is to get a brand new battery for replacement.
Please charge the new battery with your phone to indicate the battery is full before you start using it.
This will help in a long way to keep your battery life span last long.
Take care.
Apr 21, 2010 | LG Dare VX9700 Cell Phone
My acer aspire 5735Z wiil not stay charged for more than 1 hour when not one the charger and just shuts off even if battery indicator shows atleast 50% charge, is just a bad battery?
Batteries wear out with use and can be replaced easily with a new one.
If you laptop is more than one year old then most probably the battery is weak and cannot hold the charge. When a battery becomes weak its capacity to hold charge reduces considerably until you have to remove it to start the laptop (with charger only).
You can continue using it until the battery time drops to about 10 minutes. After that, simply replace it with a new one.
If the laptop is new and under warranty, you should contact warranty support asap.
To increase battery life place the laptop on a solid table where there is ample air flow beneath. Heat will destroy a battery faster such as when used on bed or your lap often.
Regarding you question about shutting down even when battery is 50% it could be due to following reasons:
  1. Power Settings within the control panel.
  2. The battery charge drops quickly so that it discharges very quickly when it is showing half. Remember that the indicator is an estimate and does not account for battery degradation over time.
  3. Other issues like over heating etc but please check first two points first.
Feb 20, 2010 | Acer Aspire 5735 Notebook
When charged V2 does'nt hold charge for long.
Hi.
Most likely this kind of problems occurs when the battery is exhausted after a long time of using it.
because even intergrated (rechargeable) Batteries Wont Last forever. the chemical substances(lithium-ion) in it Drains after a period of charging/discharging(using the device).
Solution:
if you have a common Mp3 player, You can purchase a new fresh battery and replace it. its quick and easy.
i can instruct you if you want so.
First check ebay for the exact same battery that you have inside you Mp3 Player.
Learn More about Lithuim-Ion Batteries on HowStuffWorks.com
Good Luck
Thank You.
Nov 03, 2009 | Audio Players & Recorders
Hi, this is our third Dyson DC-16.. the Trigger was shorting out on the first two.. Now we have the third one for about a year.. on charge when not using it.. don't use it every day, but for quick pickups...
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Battery dies quickly
your battery could be defective I would return it and get a new one
Aug 30, 2009 | Motorola Mobility Moto Q
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
