Question about ASUS WL-500W Router (WL500W)
Asus WL-500W USB printer - Can't add printer
I have an Asus WL-500W router. I have hooked up my HP LaserJet 1012 via USB to the router. How do I add the USB printer attached to my router, to my PC?
  • Anonymous Dec 25, 2008
    Same problem just a canon pixma 4300
  • Anonymous Feb 21, 2009
    Same.
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
Posted on Dec 28, 2008
  • chamster Dec 28, 2008
    I ment printer not harddisk, sorry
How do i set up my hp 1012 printer to print wirelessly?
1.Position the printer near your wireless network's router. Plug an Ethernet cable into the Ethernet port on the back end of the printer. Run the other end to any of the numbered ports on the back side of the router. Press the "Print Report Page" button on the printer.
2.Navigate to the setup page listed on the report page and click the tab labeled "Networking."
3.Scroll to the "Connections" heading and click "Wireless." Navigate to the tab labeled "Wireless Setup." Click the "Start Wizard" button.
4. Follow the prompts to connect the HP 1012 to your wireless network. Click "Finish" and close the browser.
5.Open the "Start" menu and navigate to "Network." Choose the "Add a Printer" option. Click "Add a network printer."
6. Click "HP Laserjet 1012" and choose "Next" and "Finish" to access the printer through your computer's wireless connection. Repeat the process of adding the printer on any other computers on the wireless network.
Please follow these steps and let me know if it works or not
Nov 01, 2010 | HP LaserJet 1012 Printer
Asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Problem open a series of ports ASUS WL-500W
Hello!
You should try to add a port range like this 7777:8000
Hope this helps!
Oct 01, 2008 | ASUS WL-500W Router (WL500W)
Can't connect my USB disk
you need the disk
this has special file on it to run usb i forget which file it is but i believe its in the 386 file on your router
other thing is you cannot use usb with a router you have to use ethernet to connect direct usb is a single setup on modem when you add a router you have to go ethernet i had to do it with mine after 2 days when i first hooked my router i called the company and found out about this thought i would pass the info along
May 16, 2008 | ASUS WL-500W Router (WL500W)
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
Printer not found
if your printer is a dedicated network printer and connected to the router, then make sure sharing is enabled and that your router is set to enable DHCP which should give your printer an ip address automatically. But if the printer is not a network printer, and is only connected to one of your pc's, then you will have to go to the printer properties in printers and faxes folder and ensure that it is set as shared, remembering the pc it is attached to has to be on
May 18, 2007 | ASUS WL-500g Wireless Router (WL500GDLX)
Open Questions:
ASUS WL-500W Router (WL500W) Logo
1,169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
