Question about Kenmore 24902 Top Load Washer
Have 80 series kenmore washer. no power. will not turn on. changed to different circut
jsrock516
  • 5911 Answers
SOURCE: My Kenmore 80 series washer won't agitate but it
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know.
Posted on Feb 17, 2009
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series won't spin
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
  • 583 Answers
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
check the link: below
http://www.repairclinic.com/0088_11_1.asp
Posted on Mar 12, 2009
JULIANFIX
  • 975 Answers
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Posted on Oct 26, 2009
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Kenmore washing machine 80 series won't spin or add water to the tub
Plug on motor (Multi-plug) may have a burnt out wire as it has different speeds. Remove and check the plug (top comes off). Any burnt wire needs to be cut back to clean copper and refitted into plug.
Dec 07, 2013 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
My top loading Kenmore Series 80 top loading washing will not run. When I noticed the motor would not engage agitation, I checked the circuit breaker and found that it had switched off. Turned breaker...
I would use a voltmeter and test the power to the motor. If there is power, then motor is faulty. If motor spins but not agitator then ****** could be bad. If no power to the motor, then a fuse or main circuit capacitor may be bad but testing with a manual and multi-tester meter will be needed to test for the failed componenent
Jun 09, 2012 | Kenmore series 80 Washer Motor 3363737-
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Kennmore 80 series top-load washer
probably the selecta switch is faulty this normally changes the wiring to motor
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
199 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
