Question about MGE UPS Galaxy 3000 UPS System
Hello Ive got cooling fault on my galaxy 3000 can u help
Try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Posted on Dec 03, 2010
  • Widlow Mar 29, 2012
    Hi there. There is no coolant in your mge galaxy ups, If its hooked up to a air conditioner it could be stating that. however if its a alarm on the ups regarding overtemp that is a hot room or a possible fan fail, or your ups is heating up due to a problem.
    hope that helps.
2 Suggested Answers
  • 14 Answers
SOURCE: Hi! Ive got "cooling fault" on my galaxy 3000. Can
hello
If this galaxy 3000 is of European Type ( that is having a radiator with coolant) , then after following proper BYPASS/Shutdown procedures, you could level the coolant in the radiator. You may require the tool kit that the supplier normally supply for this type of job.Generally the design was such that no evaporation could occur, however at times the top up is required. It may be as little as 20 (millilitre) Please check also the cooling fan just below the capacitor assembly. I hope this will help
Posted on Jun 11, 2011
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
Temperature fault. Q5N open
pls cheak by pas slecter not normal position load on by pas temperature fault 1st cheak coling water 2nd room temp 3rd cheak temperature sencer battary breakr to batt bank side 2 wair
Jul 25, 2013 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
Galaxy 3000 30kVA showns battery charge fault.beacause battery?
UPS battery must be tested individually before you can decide it is a battery problem or if charging fault can cause by defective rectifier/charger board.
Sep 09, 2011 | MGE Galaxy 3000 UPS System
hello
Jun 08, 2011 | MGE UPS Galaxy 3000 UPS System
Mge galaxy 3000 how to reset battery expire alarm after battery change
Unfortunately the reset is only possible with MGE software (Softunor).
Jan 24, 2011 | MGE UPS Galaxy 3000 UPS System
I have a cooling fault error displayed on my galaxy 3000 mge ups please help on how to solve it
u must be open the tope of cape and u will see top of the back site in ups condenser I mean cooling system like AC condenser u will have to pull it off the sensor switch it sure u problem will be resolve
Sep 15, 2010 | Refrigerators
I had problem with my MGE Galaxy 30KVA. The problem is batt temperature fault and now the UPS status is not protected. I have tried to restart the UPS but the error still shown and cannot be deleted....
I have a temperature fault in my galaxy 3000. Try to clean the radiator behind the cabinet with the air compresor and clean all the fan inside so air circulation is good. Don't know about batt temperature fault. Hope this help.
Sep 15, 2010 | MGE Galaxy 3000 UPS System
Rectifire internal fault
the mge galaxy 3000 ups dont start atall when switch to normal position
Apr 06, 2009 | MGE Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
MGE UPS Galaxy 3000 UPS System Logo
1,293 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
