Question about Amigo Health & Beauty
Need to replace battery charger - part #7478 - Amigo Health & Beauty
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How to replace video card
You may need a PCI-VGA or AGP Video card depending upon slots available on your PC's Motherboard. Check your PC's documentation for supported models and add a card.
Aug 03, 2014 | Compaq Presario 7478 PC Desktop
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
The charger for my HP G62-347NR gets very hot when plugged in and batterys doe not last long after charging I was wondering if my charger is bad?
If your charger is able to power your laptop while the battery is out and it can do it well then your battery needs replacing. Your charger is heating up because the battery is offering resistance, to the charger. In other words it is not accepting the charge provided by the charger.
You most likely need to replace the battery, be sure to get the correct battery for your laptop. One that is also compatible with your charger.
Would you please be so kind as to rate this session, thumbs-up on the right.
Take care!
damnor01
Apr 20, 2011 | HEWLETT-PACKARD ProBook 4520s
Bios battery location on a compac t 7478
The location of the Bios Battery is on the main motherboard, the battery is silver and looks like a large button.
Jan 15, 2011 | Compaq Presario 7478 PC Desktop
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
Health & Beauty Logo
Top Amigo Health & Beauty Experts
James Rose
Level 1 Expert
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
