Question about Motorola Mobility Q9m Smartphone
Motorola Q9 After my phone went flat I can't turn it on. The screen is blank. It is on the charger but I can't tell if it is charging or not. Any suggestions?
  • s_singh Jun 01, 2008
    Have the same problem, phone worked great, battery died on my and I plugged it for an hour< when I tried to turn it on it goes black on doesn't do anything.
    Problem Solver:
  • 4 Answers
It's sound to me like you guys might have dead cell... change the battery and it should be fine.
Battery Maintainance
1: Try and charge battery when it's totally off/flat
2: Only charge battery till battery full indication comes up.
3: When disconnecting battery switch phone off first.
4: When phone is not in use don't leave it in the sun facing the battery.
.....Hope this helps.
Don Cass
Posted on Jun 18, 2008
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
My razor will not turn on and will not charge. when I try to turn it on the lights on the key pad flicker and the screen is blank
Please chech your phone charger with any other compactible phone for its faults.may be the charger is not working properly & its is not able to charge your phone
Feb 25, 2010 | Motorola Mobility RAZR V3
New Motorola SLVR is suddenly unresponsive, won't turn on
Try to replace the battery and if the unit is still under warranty advise the store to replace the battery.
Jun 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Mar 24, 2009 | Motorola Mobility i880 Cellular Phone
Motorola E815 has been paired with VRBT300V Bluetooth
I just bought this unit today at Costco.  I read a post on yahoo that said to make sure that you hold the on button long enough to see the blue and red lights flashing.  Once I did that my cell phone had no problems finding the unit.
Jun 29, 2008 | Lands Phones
Blank Screen
Sounds like the charger's defective. Did it get dropped accidentally? Take both the phone and the charger back where you got it. They should fix the problem for you. Battery in the phone is probably dead and just needs charging.
Aug 19, 2007 | Motorola Mobility RAZR V3
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Jun 24, 2006 | Motorola Mobility V710
Motorola Mobility Q9m Smartphone Logo
116 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
