Question about Double Decker Triple Decker Jogger Stroller
Instructions to attach the toddler seats for the triple decker stroller.
Have just bought a toddler seat need instruction manual on how to attach toddler seat to bertini stroller please help
Hi, you have to remove the bumper bar and the hood, then click the toddler seat into the opening that the hood goes into, once in, you can then refit the hood but you are unable to use the bumper bar with the toddler seat in position.
Jan 17, 2011 | Bertini Chrome Stroller
I bought the Peg Perego Venesia Stroller and Primo Viaggio infant car seat used. I do not know how to run the straps through the infant carrier or how to completely attach the carrier to the car seat...
hi I'm sure this is just the newer model the uno looks the same as the venezia
http://global.pegperego.com/babyproducts-catalog/2010/Uno
instructions available at this website
Nov 17, 2010 | Peg Perego Primo Viaggio Verde Infant Car...
How to remove, clean, reinstall seat on Maclaren Techno Stroller
If you follow this link to the instrucitons on the maclaren website, the instructions tell you how to remove clean and reinstall the seat. http://us.maclarenbaby.com/toddler-buggies/techno-xt?lang=en
If you have any trouble call maclaren customer service at 1-877-443 4622
hope that helps!
1 877 442 4622 info@maclarenbaby.com
May 31, 2010 | Maclaren Techno XT Standard Stroller
Install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
Nov 24, 2009 | Graco Snugride
I need to set up the pram for a toddler and new born and have lost the manual
You will need to recline the main seat unit fully (undo the zips on the inside of the seat unit) and attach the toddler seat on top (with two right angled connectors put into the slots where the bumper bar clicks).
With this setting, you will be able to use this for a toddler and newborn.
I hope this helps.
Oct 28, 2009 | Phil & Teds E3 Jogger
I have been given a near new emmaljunga pram- it's navy blue with the white tyes and blue steel all in great working order. The problem we can;t figure out id how to turn the seat attachment to face the...
Where the seat attaches to the frame (on both sides) there is a lever that you undo to release the toddler seat - the lever is on the handle side of the frame. Unlock the lever by pulling it towards the handle, then taking hold of the toddler seat slide it towards the handle. This causes the toddler seat to release and allows you to tilt it and lift out. Turn the seat around and reverse the process, remembering to attach the "lock end" first. Hope this is clear!
Oct 04, 2009 | Emmaljunga Coronado Stroller
Does toddler seat for emmaljunga fit all pushchairs of emmaljunga make - bought pram 2002.
No, the older toddler seats will not fit the newer model strollers. You will need to check the toddler seat and see how it attaches to the pram, there are two different styles.
Apr 01, 2009 | Emmaljunga Baby Gear
Toddler Seat Accessory
I went to the Valco site and wrote and email to the Support Team and they emailed me the instructions to collapse the Toddler seat with the pram. The pram now 'squashes' nicely!
Jun 26, 2008 | Valco Runabout Deluxe Jogger
SAFETECH TRIPLE STROLLER
I want to buy a triple jogging stroller how do you get a hold of this company to buy one?
May 30, 2008 | SafeTech Triple Jogging Stroller
Double Decker Triple Decker Jogger Stroller Logo
101 people viewed this question
Top Double Decker Baby Gear Experts
Dorel UK
Dorel UK
Are you a Double Decker Baby Gear Expert? Answer questions, earn points and help others
