Question about Magellan Roadmate 760 GPS Receiver
Turns off when I move it slightly
When I power the unit on it is fine until I move it slightly and then it turns off. Thought it was the battery connection but it seems tight. Any solutions? Thanks
The docking cradle is probably the problem. I have the same problem and the power connector inside the docking cradle is broken. I am trying to find a part number to replace it, the part should run about $1, much cheaper than buying a new cradle that will break again anyway.
Posted on May 28, 2008
  • 65 Answers
It must be in the wire...............
get a new cable(power) and try that!
Posted on May 12, 2008
Htc 8s water damaged?
It is a water demage - with using to quickly you made it bad, I guess with pressing the screen you moved the water.
I would say ... give it another dry (smile)
Open the rear, take the batterie out ... mean let the mobile breath ... then leave it on a warm, but not hot place ... it has to stay on the side. We want that the water in the case vabours troughthrough the side buttos within the time.
Feb 04, 2014 | Computers & Internet
Acer netbook loses power, turns itself off
I would get the battery first. But worst case you have a bad power connection on the board that needs to be resoldered or replaced.
Apr 14, 2010 | Acer Aspire One AOA150-1784 Netbook
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
All lights & horn work, battery showing full charge, won't run, not even a clic. Key turns on, controll unit flashes 6 times in repetative cycles...Any ideas?
ok, that can be a number of things, first of all trying moving the throtle to the left slight then turning on, thry the right side as well, now the idea is if the pot (wig wam etc) has moved it means the throtle is in hte wrong location otherwords a error ,
Regards
GeWiz.
Sep 24, 2009 | Electric Mobility Mobility Electric Power...
I got an Insprion 2200. It turns on, but once I move it the power cuts out. Not sure if it's the ac jack on the back of my laptop or another internal problem. Even with the battery in there left to charge,...
The DC connect on the system board may be loose. Take hold of it at the connection and wiggle it slightly. If it moves alot, the DC connector on the board is loose.
If not, take your battery out and power up the unit and see it stays on. If it does then it is the battery.
Jul 18, 2009 | Dell Inspiron 2200 Notebook
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
My Akai DC-7370 turns on, I see the welcome screen corporate logo on the LCD screen but then it immediately turns off.
i had the same problem with the same camera, you need to get the ni-mh rechargeable batteries, i just got the kodak 1 hour charger with 4 AA batteries, and it works just fine now
Dec 25, 2008 | Akai Dc7370 Digital Camera
No power at startup on Sharp LCD-32gd8e
Hard to diagnose some problems without hands-on. However, my guess is the power supply is fine, as are most on LCD's. The inverter board which powers the screen is the most likely cause of problems on that model set. Only other thing that i've seen is a shield that moved slightly beneath the main pcb. It moves because the putty that holds it in place was not rated at a high enough temp. and it simply turns to goo, allowing the heat sink to slide down and touch the main board. Three boards must be removed to find this problem. By holding down the power button on the set you may not be allowing the shutdown circuit to engage which means the problem could still be anywhere in the set. Sorry I can't be more help. All you can get is a guess here.
Sep 01, 2008 | Televison & Video
It turns off if moved
sounds like you damaged the battery or the logic board. get it serviced
Mar 14, 2008 | Nintendo DS Console
Magellan Roadmate 760 GPS Receiver Logo
59 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
