Question about Trekstor (21329) 250 GB USB Hard Drive
Trekstor datastation ac power unit dc pinout - Trekstor (21329) 250 GB USB Hard Drive
  • 3 Answers
SOURCE: not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Posted on Dec 16, 2008
Alcatrazx
  • 65 Answers
SOURCE: external harddrive not recognized
Hi there
I am assuming that you are installing this on VISTA or XP. First of all you should make sure that you are actually connecting to a reliable power source because most of the time the USB enclosre you are connecting to would not supply sufficent power to power up the drive so I do not think that at this point in time it is a driver issue. Also make sure that if you have 2 wires you connect BOTH and not just one of them to the USB. If you have WIN XP Service pack 1 upgrade to Service pack 2. Vista should be ok. Another thing you should check is that if you have another computer (different brand if possible) see if this drive works fine on the other one. Also make sure that if you are connecint you hard drive to the FRONT USB try the BACK ONES and seee if that improves matters. Last thing you should check is the BIOS settings: make sure that you are the voltage of the USB's is set to the highest possible and that the mode is USB 2.0 (in CMOS). Hope that these solutions will solve your issue!
CHEERS
Posted on Jan 09, 2009
  • 12 Answers
SOURCE: DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Posted on Jul 29, 2009
  • 7 Answers
SOURCE: Trekstor TrekStor DataStation m.u stopped being recognised by PC
Have you tried going to the manufacturer's website and downloading and installing the drivers for your product?
Posted on Sep 03, 2009
computus
  • 487 Answers
SOURCE: Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Posted on Jul 10, 2010
Software for TrekStor DataStation pocket x.u
http://www.trekstor.de/product-support/product/datastation-pocket-xu.html
Sep 30, 2014 | Computers & Internet
Need software because my computer says it needs to be formated
Improve the Fixya.com experience for everyone by voting!
Click on the following link for the official Trekstor DataStation Maxi mu site: Trekstar DataStation
If that official site doesn't provide you with the required driver, continue reading.
Click on the following link for the largest FREE driver database on the internet. Driver Download
All the best,
Ben
Jul 15, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5" External Hard Drive 1TB & USB 2.0 on the floor. When I turn it on the light illuminates however when I plug it into my computer it doesn't even...
Mechanical damage. Last possibility to retrieve the data on it: open the case, extract the hard disk, put it in a desktop and try to access it in there. If even this fails then it's dead, junk it.
Feb 04, 2011 | Trekstor 88470 DataStation duo w.u 1TB...
I have Trekstor Datastation maxi 160Gb hard drive, I dropped it, making a terrible clicking noise, laptop or telly won't see it when plugged in, trying to remove casing, took 3 screws a long bottom, can't...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 08, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
I have a external Trekstor DataStation maxi 500 Gb hard drive. I now have encountered a constant red light and when this happens the drive is not visible in Explorer. When I turn off the power and then...
At the least, the device is "unreliable", and it would be wise to replace it, either by exercising the warranty (if the warranty still is valid), or by opening the enclosure, removing the disk-drive, buying a new (and compatible) disk-drive, inserting the new disk-drive, and closing-up the enclosure, to create a "new" external storage-device.
Sep 18, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Sep 03, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Datastation m.u stopped working : (
Dropping a drive can be catastophic but usually isn't.
I suspect you may get lucky and find out it's just some of the circuitry in the trekstor shell that is damaged.
Take the Trekstor unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor (21329) 250 GB USB Hard Drive Logo
32 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
