Question about KitchenAid Dishwashers
Our kitchenaid dishwasher model: kudio1lbl6, doesnt work. no lights, there is power at its box
Dishwasher does not work. The power is on but when you push start it doesnt go on. When you hit cancel it goes on for a few seconds then shuts off.
Posted on Sep 11, 2011
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Heat dry stopped working. button still sounds but doesnt light up. Neither does the drying light after the wash cycle
you must press the button and hold until the light comes on. if this doesnt work then there is a problem in the pcb and it will have to be replaced, which is costly, so look into an extended warranty first
Sep 27, 2013 | KitchenAid KUDC10IXSS Builtin Dishwasher
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
My KitchenAid model KUDSO11JBSO dishwasher stopped running before the last cycle (drain) finished. All the lights and any response from the touch pad have gone out. There is still power to the junction...
Try shutting off the power at the breaker, leave it off for 45min. This will reset the unit. If you had a power spike this will fit the issue.
Nov 09, 2010 | Dishwashers
We went to run our dishwasher and lights are out....nothing works......house fuse fine. Been told to look for fuse box inside of dishwasher panel but cannot identify.
if the circuit breaker is good then you need to check the main power line to the unit and make sure everything is connected properly.
Oct 24, 2010 | KitchenAid Dishwashers
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
The light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
May 31, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Where is the fuse box on a Kitchenaid dishwasher, KUDP02CR?
There is no fuse box inside the dishwasher. The fuse box or electrical panel for your house is where you shut off the power to the dishwasher.
please mark this answer as a fixya!
Mar 09, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher not working
Check for power with a tester at the junction box under the machine. If power check for a broken door latch switch.
May 31, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwashers Logo
180 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
