Question about GN Netcom GN 9350 Wireless Headset
I am hearing the out of range tone through the headset even though i am sitting right at my desk
SET A RINGTONE & PLAY MUSIC
u need to change the phone sound ic or change the phone speaker.
Feb 13, 2012 | Samsung B3310 Cell Phone
Even though my H12 is paired and it will dial the last call, I do not have any sound. I do not even hear the initial tone when i turn it on.
unpair it from your device and pair it again or try restarting the device your connecting it too and unpair and pair it again. Hope this works!
Sep 10, 2011 | Motorola Mobility Motopure H12 Bluetooth...
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
I can hear my voice in my headsets..its very loud..if I blow into the mic..its like an actual live mic
all headsets feature what I think is called side tone. you need to hear a bit of yourself when speaking on a microphone as a bit of communication reassurance. When thew microphone level is up way too loud , that's more than side tone, it's annoyance that's when you get the problem that you've listed. I've seen it on telephone headsets and Mobile Phones but i'm sure it would happen on gaming headsets too...
Good Luck
Jan 17, 2010 | Logitech Audio Players & Recorders
My headset has a constant buzzing in earpiece. Even when no line is selected. Can't hear dial tone.
On left hand side of base unit dial has to be set with the number 1 in the 3'oclock position. On the right hand side of base unit there is a switch set it to the 1 position. On the headset press and hold the vol - and vol + and pick up call buttons at the same time until an orange light on headset blinks a few times.
Problem solved
Jan 04, 2010 | Plantronics Radio Communications
Pairing motorola hs810 with sony ericsson k800i
unless it is a stereo bt haeadset is the only way you would hear a mp3......
Aug 18, 2008 | Sony Ericsson K800i Cellular Phone
CS50 headset with lifter not beeping when away
It is the handset lifter that actually picks up the ring tone from the telephone, and not the CS50 itself. The first thing that you want to do is make sure that the ring tone or ring volume didn't change on the phone, because this could throw off how the lifter "hears" it. Also, I'm not sure which lifter your user has.. if it's the larger HL1 (this one has a base that the phone sits on), there is a sensitivity adjustment on the back of the lifter. If is the smaller HL10 which sticks onto the phone (and should be positioned over the speaker grill where the ring tone comes out of the phone), the internal mic may have stopped working and that could be why it doesn't hear the ring anymore. If you have the HL10, you can try using a ring detector cable, this is a little accessory that should have come with your lifter (it looks like a wire with a small speaker on the end of it with double-sided tape). Plug this into the back of the HL10 (there are 2 jacks back there but it will only fit in one, you may need to remove the rubber plug), then stick the little speaker over the speaker grill on the telephone. If this doesn't work, you may need to replace the lifter. Here is a link below with a picture to take a look at the ring detector. Plantronics 46780 01 Ring Detector Cable PLX Headsets Direct
Aug 25, 2017 | Plantronics PL-CS50 Professional Headset
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
GN Netcom GN 9350 Wireless Headset Logo
120 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
