Question about Little Giant 554425 VCMA-20ULS 115V 20'
Little giant vcmx 20 pump how do you reset the pump after it turns off the air conditioner
  • Little Giant Master
  • 43,501 Answers
The switch in the pump should reset it's self after the water is gone...the problem is that the furnace or air condittioner is in a soft lock out and you need to recycle the power to that to get it to come back on...
So turn off the t-stat or turn off the breaker and then turn them back on... it should work then...if not the float could be hung up in side the pump...
Take the wires and bug them together at the pump to bypass it...then repalce the switch or the pump...
heatman101
Posted on Sep 04, 2010
Why is unit flashing ch02 code?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioning Coral Springs
May 23, 2014 | LG LSN240HSV LSU240HSV 24,000 BTU 18.9...
Little giant pool pump cover will not work
auto switch is defective? a simple easy replacement can be sourced from any pool supply co
Jan 18, 2014 | Little Giant Pool Cover Pump Water Wizard...
Hello, my little giant dinosaur pump stopped
No reset, the pump may have just failed internally, try another plugin to varify power, if no joy than look at a new pump
May 14, 2010 | Plumbing
My little giant 554425 will not come on
Either the float is stuck or the pump is stuck...
To release the float a good shot to the side of the pump is all that it will take....
If that does not work then a few screws and the top will come off.. the pump is a very simple spinner.. make sure ther is nothing jammed in there...
if that all checks out replace the unit, the motor is shot....
you should be able to find a new one at a HVAC supply house for around fifty bucks...or check www,grainger.com for a replacement condensate pump.
heatman101
Apr 07, 2010 | Little Giant 554425 VCMA-20ULS 115V 20'
Does not turn on when submerged,,works when I manually pushed the switch
Often a little giant will air lock and you may have to tip on it's side to get the prime to start.
Apr 04, 2010 | Little Giant Big John Lgp 4/10 H.P. 54...
How do I reset the float. The pump cycles every
Check your check valve first. If it breaks, the water in the verticle section of pipe will run back into the pit when the pump kicks off and causes short cycles like you describe. Otherwise, what type of float? What brand and model pump?
Dec 12, 2009 | Little Giant Plumbing
Little Giant 554425 VCMA-20ULS 115V 20' Logo
205 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
