Question about Sport & Outdoor - Others
What to do to shorten draw length on a pse baby g force
What type of extension lead can i attach to the lead of the charging unit as i live about 35 foot from where i can park the car for charging
A 12 gauge extension lead would do the job. However, typically they only are available 25 and 50 foot lengths. It would be okay to coil up the extra length if you go the fifty foot route. Alternately you can cut off the length you don't need and attach a female receptical. If you opt to shorten the cord, take care to not strip the outer sheath to far back. The cord strain relief is the clamp on the cord side of the receptacle and is intended to counter the forces produced while using the extension lead. The clamp must be able to close and clamp the sheath once the plug is assembled.
Apr 06, 2016 | Computers & Internet
How to adjust the needle when using the zig zag mode
All machines are similar.
Push the zigzag control to begin: To control the zigzag appearance the width and length have to be changed.
Width: This is to control the width just as it says; wide.
Length: This is the length of a straight stitch. As it is made longer the length of the zigzag from one tip to the next tip will lengthen. If it is made shorter the tip to tip measurement will shorten.
This is easy to learn. Give it a try on old material.
May 19, 2015 | Baby Lock Sewing Machines
Two forces of 5 N and 12 N respectively act on the same point. show how you would determine the magnitude of the resultant by using the tail-to-head and tail-to-tail methods and pythagoras theromen (13 N)
Draw a vector of length five. From the head of it, draw another vector of length twelve. Now measure the distance from the tail of the first vector to the head of the second.
If the two vectors are at right angles then Pythagoras' theorem applies. Square five to get 25. Square twelve to get 144. Add them to get 169. Take the square root to get 13.
Jan 24, 2014 | USAF Security Forces Shield Decal
Want to know the proper length of the drain hose from washer to drain. I can shorten it to about 6" if need be
You cannot shorten it to 6 inches. The pipe must go up from the bottom exit up to nearly the height of the washer then down anywhere to drain pipe in wall or washbasin. But the drain hose must go first up and then down - important.
You can give me 4 thumbs, if helped that is.
Jan 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Aug 26, 2012 | Betsey Johnson Archery
What is draw weight?
Generally, the draw weight is the amount of force to pull the bowstring to a certain draw length. The industry standard is measured in pounds at 28 inch draw length.
How do I shorten the stitch to make a rolled hem? Please help.
For the rolled hem: the needle is in the O2 or right position, the length is 1.5 in the rolled section- you will see this, if you look on the side of the bottom knob- you can decrease this to 1, but you have to stay within the rolled section, the width is 3.5. the stitch selector is on D, the upper looper selector is UP, the blade is engaged and the subsidiary looper is to the right. You can use a decorative thread in the upper looper- Madeira Decor, Superior Threads made for bobbin work, or YLI Pearl Crown Rayon- or use a wooly nylon for excellent coverage and not need to decrease stitch length. I usually don't need to change the length with these threads.
May 21, 2010 | Baby Lock Evolve
Washed and need to put buckles back together
Always make drawing and notes of any componentry no matter hw suimple before you take it apart.
Imagine the dimensions of the baby/child in the seat to coordinate the right lengths of buckle hasp sections to required to the buckle tongues [we can term them].
Sep 19, 2009 | Evenflo Big Kid Booster Car Seat - Napa
The hip belt rides up
You need to adjust the torso length. The adjustment is directly behind the part that goes against your back.
Jun 13, 2009 | Kelty Kangaroo Baby Carrier
Sport & Outdoor - Others Logo
464 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
