Question about Maytag MED9700S Electric Dryer
My dryer is not getting power. - Maytag MED9700S Electric Dryer
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
Tip
Electric dryer will not work at all?
If the electric dryer does not work at all then there are some possibilities that have to be checked to confirm the fault.
1) Check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not working is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) One more reason for dryer not working at all is the fault in the door switch. The dryer will not start working till the door is closed. But if the door switch or the door-switch actuator is got cracked or worn out or loose then door will not get closed properly and dryer will not work. In this case check the door switch/actuator and replace it if required.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get power and will not work.
This will help. Thanks.
on Mar 23, 2010 | Dryers
My Kenmore Dryer will not start. We replaced the Receptacle but it still will not start.
Make sure the dryer is getting power by checking the breakers. The dryer usually has a drum lamp that turns on only when the door is open. Power is indeed getting power if the lamp turns on. If not, either the lamp is busted, the door switch is not working, or the dryer is not getting power at all.
The problem is likely a blown thermal fuse if the dryer is getting power. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed procedure in checking for such condition.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Feb 11, 2011 | Kenmore Dryers
Dryer is not getting power but circuit breaker is
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Also this tip will help you check the power at the back of the dryer..
Check the instructions in the last paragraph for checking voltage at the dryer...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Apr 07, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats up and is getting power, but the door
door switch is fine or it would not heat or do anything
more than likely its a bad belt
Oct 08, 2009 | Dryers
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 11, 2009 | Frigidaire Electric Dryer
Not getting power
Sounds like maybe a door switch, thermostat or the thermal fuse. You can check for continuity across the terminals with dryer unplugged. Usually the thermal fuse and thermostats are located by the heating element
Apr 04, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Maytag MED9700S Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
