Question about Ford Tractor Naa Golden Jubilee Emblem
Ford jubilee hydraulic leaks oil from the bottom of the bell housing. I added hydraulic oil to the oil filler on top of the transmission and it leaked worst. I took of the hydraulic pump and replaced the two o-rings on the oil connections. Can you add oil for all three reservoirs at the same place?
SOURCE: Power steering pump leak
replace the pump . the pulley takes a special tool you should be able to rent one at autozone
Posted on Oct 04, 2008
  • 34 Answers
SOURCE: 2001triton v10 oil leak
i believe you are looking at the oil cooler, replacing the gasket is not that difficult, drain the radiator, remove the oil filter and it should be 4 bolts and the whole assembly comes off, keep in mind though its more common for the oil filter itself to be leaking rather than the oil cooler gasket.
Posted on Dec 02, 2008
  • 45 Answers
SOURCE: how to add or check transmission oil
this t-bird has a 5r55s trans. it does not have a dipstick.
it has a "standpipe" type leveling system.
to check fluid level the tranmission has to be within 80-120 degree f.
take the plug out of the center of the fitting located on the bottom of the trans pan. it is a torx 30.
running in park the fluid should drip slower than a coffee pot.
to add you need a npt thread fitting the same as the little plug you removed. and attach a bottle of mercon5 and hose to it. squeeze the bottle to add fluid
then recheck it by letting it drain out to a fast dribble. then install the little plug back in.ead6e26.gif remember 80-120 degree fluid temp.
Posted on Feb 02, 2009
centralvalle
  • 386 Answers
SOURCE: 95 ford escort transmission leak
Dont waste your time and money trying to use a transmission stop leak product, they don't work on large leaks, you say the leak is excessive in this case the you must remove the transmission to access and remove the torque converter, after you have removed the torque converter carefully inspect the torque convert imput shaft for wear and also you will need to visually inspect the transmission front pump bushing for wear also, I have seen it all to often people just replace the seal thinking it was just a seal failure, well more times than not there is a reason for seal more than just the age of the seal, excessive wear on trans pump bushing and torque converter imput shaft is usaully the cause, check and repair those as good practice during this repair unless you just like to do the repair over again for free... also check the torque converter run out, sometime when they are repaired they are welded back together somewhat crooked which will cause it to spin off of a true center, this will cause immediate damage to transmission. Check also your engines crankshaft end play for looseness this can cause wobble which will transfer to transmission causing this problem as well... do the repair thouroughly and who ever does it for you have them check all that I listed and you should get a good repair which will last without issues.... please rate my help thanks...
Posted on Aug 08, 2009
  • 2309 Answers
SOURCE: water leak on a ford taurus between the transmission and oil pan
there are frost plugs on the engine block behind the bell housing, bu first make sure that the plugs on the heads are not leaking, removal of the trans, is no fun but may be the only solution
Posted on Jan 27, 2010
Ford f-250 transmissiom leaking fluid
What's causing this transmission leak? - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 1999 - 2003 7.3L Power Stroke DieselJun 14, 2011 - I've never had a drop of fluid leak from my transmission until yesterday. I towed a very heavy ... 2011 Ford F250 King Ranch SB CC. Magnum ... 2002 F250: Transmission fluid dripping (pic)
May 29, 2012
leaking transmission fluid
Jan 6, 2011
Leaking Transmission (with pics)
Mar 23, 2010
ATF fluid leaking out of bell housing ?
Apr 6, 2008
More results from www.ford-trucks.com
Jul 14, 2014 | 2007 Ford F-250 Super Duty
Hydraulic leaking
Do you have a hydraulic operated clutch? The slave cylinder for a hydraulic clutch would be on or sometimes inside the bell housing. Some ford and chevy trucks put the slave cylinder in a very difficult to reach place-the transmission has to be removed to service the slave cylinder. Most cars have the slave cylinder mounted on the outside of the bell housing. If they leak, replace or rebuild, although those internal slave cylinders I think can only be replaced.
Dec 31, 2013 | Cars & Trucks
Leaking fluid hydraulic clutch
I would check for fluid at the bottom of the bell housing. The slave cylinder is inside the housing and known for leakage problems. The transmission would have to be removed to replace it.
May 13, 2013 | Ford F-150 Cars & Trucks
Leaking from the front of bellhouseing
Gday mate,geoff here, there are 3 things that can leak there, 1st is coolant as there should be a freeze plug at the back of each cylinder bank in there.
2nd engine oil as there is a seal on the crankshaft and a plug at the back of the Cam tunnel, mostly if its engine oil it will be the crank seal.
3rd is gear/transmission oil, front seal on the gearbox if that is the case, also make sure that the oil isn't coming from the top and leaking down to look like its the bell housing leaking, as the valley cover and rocker covers extend back to just above the bell housing, hope this helps, geoff.
Feb 11, 2012 | 1997 Ford F250 SuperCab
Have a major oil leak
The oil sending unit is located behind the intake next to the distributor. check for fresh oil, if none is there then check inside the bottom of the bell housing of the ******. if alot is there it could be the rear main seal.
Dec 13, 2011 | 1995 GMC Jimmy
I have a 2001 ford windstar with the V6 engine, when traveling for a long distance I started to get Transmission oil leaking and when the car cooled down it was fine......I was told the filter could be...
Where is the oil actually leaking from? If it is from the bottom of bell housing the leak is from the oil seal on the shaft at the back of the torque converter. This is transmission out job to get at it. It is best to have this fixed as the low fluids that will result from the leak will result in poor torque converter performance and then to worn gear clutches ruining the whole transmission. As an interim measure it is possible to top up the autobox when it gets low by adding the right (really important that it is right) fluid via the transmission dipstick tube (NOT the engine oil dipstick tube).
May 26, 2010 | 2000 Ford Windstar
Transmission fluid leaking from bell housing when in gear.
If you have never done this before,it may be best to take the truck to a shop or have some one with experience help you. You will need the truck up far enough to take out the transmission. The linkage and drive shaft has to be removed,then unbolt the transmission from the bell housing.Special tools may be needed to pull and replace the seal.
Transmission fluid needs to be changed since it is a brownish color.
Feb 16, 2010 | 1992 Ford Ranger
Water leak on a ford taurus between the transmission and oil pan
Jan 27, 2010 | 2000 Ford Taurus
Clutch pedal has no pressure
check the fluid level in the clutch reservoir,make sure its full,the hydraulic slave cylinder is located inside the bell housing you can check that by looking around bottom of transmission for fluid leak,these systems are hard to bleed air from ,
Dec 15, 2009 | 2003 Ford F150 Regular Cab
Leaking clutch 85 s10 blazer when I bleed the slave cylinder oil leaks out the bell housing
First, unless you have just done some clutch work you should not need to be bleeding the clutch hydraulic system...that shows that it's leaking. There is nothing inside the bellhousing that has anything to do with clutch fluid, so, the fluid you see is either engine or transmission oil (rear main seal or seal on trans input shaft) Could it be that the clutch slave is leaking and it's running down and dripping at the bottom of the housing? (clean it up and check that)
Jun 17, 2009 | 1985 Chevrolet S-10
Ford Tractor Naa Golden Jubilee Emblem Logo
318 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
